Damper with Synthetic Rope?
nU7OuxIx
Chicago
2025 JLU Rubicon X, YJ, Impreza
Quick question, do you need to use a damper blanket when using synthetic winch rope? What about if using kinetic rope?
I would think not because it doesn't store nearly as much energy as a steel cable, but I don't want to be unsafe either.
Thanks in advanced!
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
I would think a damper would not be needed with synthetic rope, no harm in using one but synthetic won’t do the damage that a steel cable will do.
RedundanT
So. Il
2020 JLUR
If you feel safer then by all means. Saying that "usually" the synthetic rope will just snap and fall inline to the pull. Usually.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I've seen synthetic lines snap under tension. It won't take someone's head off, like a steel cable, but it's still no different than being whipped with a bull whip. I plan on using one on my synthetic line, because I'd rather avoid having to apologize to someone for the permanent scar.
donmontalvo
Don
Livingston, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
Synthetic rope snapping while winching? I would never take the risk. Throw something over that synthetic line. Don't take unnecessary risks.
kkarnage
2022 392, 2020 JLUR, 2015 JKR
It's not just about the line snapping and whipping back. Depending on your particular setup, you may well have a shackle connecting the steel connector end of your winch line to the thing being winched: if that shackle breaks, your line still has that chunk of steel on it, and that is going to come back toward the winch at a rate of knots, and that will not only take out whatever body parts it comes into contact with, it will probably turn them into mush.
Just damp it. At worst nothing happens and you don't need the line damped.
Willing&Able
IL
2023 392 20th Anniversary
HIGHLY RECOMMEND!!!!
I was stuck in snow last spring up north and was in the Jeep operating winch and partner was strapping to a tree using gator jaws. They did not fully secure the loop over the knot. After what I'm guessing is a few thousand pounds of force the loop slipped over the knot and the several pound Factor 55 link flew back at the Jeep so fast I didn't even see it. It flew underneath the entire length of the Jeep and dozens of feet beyond.
No doubt this would severely injure or kill a person and/or seriously damage the front of your Jeep. I now have a damper I keep in my recover kit....
thelumen
james
usa
Rubicon 392
Thanks in advanced!
a lot of those synthetic ropes tend to disintegrate rather than snap but you may have dangerous bits for hardware such as hooks or shackles that might come flying, so can’t hurt
