Creaking Doors...anyone?
JLSpartan
Roman
Michigan
18 JL Sport
Hey all, this started probably a few months ago but has been getting worse and worse. My driver-side door started to make a creaking sound when opened or closed. "It's a Jeep thing" I thought at first, but it started to do it more and more and my passenger-side is going in the same direction. These are only the front doors on my JLUS, so far. I've tightened any bolt I could find and determined that it is happening towards the bottom of the door. If i insert my fingers into the metal seems of the door in that area and pull a bit, there is no sound while moving the door, but that only solves it while I'm pulling on the seems. If i put my fingers on the inside wall of the door around the bottom front corner i can feel the creaking inside the door. Best I could really explain it, here is a video :)
Anyone else experience anything like this? Any thoughts?
Thank you
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Yea, mine got really loud after I took my doors off and put them back on. Try removing the door check mechanism.
W1ck3d
Toledo
2019 jl rubicon
Loosen the torque on the hinge bolts... I think spec is only like 5nm
JLSpartan
JLSpartan
Roman
Michigan
18 JL Sport
Ladies and gentlemen, grease your hinges.
So I'm pretty sure it's not the hinges, no issues there. It really feels like it's inside and has something to do with the door check mechanism as @mwilk012 pointed to. I'll try removing them and seeing if that does anything.
Swanny297
NELA
2018 JL
Mine does it and I have greased everything even the mechanism inside the door - it isn’t the hinges or door pins, I don’t have my door pins bolted on so thought that may be it but it wasn’t - gonna try loosing the door stop mechanism and see what happens.
bikenutty
Cash
Anaheim
2018 JLUR - 2018 Raptor - 2021 Tuono - 2018 NC750X - 2015 Yamaha 212SS Jet Boat
Facilites Manager
mine just started a week or so ago....
JLSpartan
JLSpartan
Roman
Michigan
18 JL Sport
Posted in a few JL Facebook groups and also seems to be an issue for a number of people. Tried greasing everything and using WD40 with no success. It does seem to be something in the door.
I'm going to take it to the dealer in a week for some other stuff and have them check this out as well.
It's odd, but if I stick my fingers ok no this groove by the weatherstripping and pry it a bit while moving the door the sound goes away.
Anyone else try that?
Jeep Wrangler JL Creaking Doors...anyone? 54A0003E-56A8-4EA7-B5B7-CEAA6503621C
Jeep Wrangler JL Creaking Doors...anyone? 3B977DEC-F7C8-476A-9A35-103DF3DACAD5
mwilk012
Service
Try taking the door check mechanism off and seeing if the noise continues.
JLSpartan
JLSpartan
Roman
Michigan
18 JL Sport
I did that actually and the noise goes away. I am positive it is something on the inside of the door that the mechanism is connected to. Tightening it yielded no results. Loosening it up made the whole thing wonky but still had the creaking.
JeepCares
Auburn Hills, MI
JL
Hi JLSpartan,
We understand why this concern may be frustrating. If you would like some additional assistance while your JL is at the dealer, please send our team a private message!
Alex
Jeep Social Care Specialist
JLSpartan
JLSpartan
Roman
Michigan
18 JL Sport
Hi JLSpartan,
Alex
Thanks Alex, you guys have been very helpful in the past, I'll see where the dealer goes with this. :)
