Cost to install and Diff lock.
adeehalasa
Eddie
Rancho mirage
Jeep Wrangler
Hello, I am new to jeeping and I just got my 2016 wrangler. I am looking to install a real diff E-lock and I was wondering if anyone can advice regarding the best E-lock and what is the average cost. thank you.
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Part of the Northridge4x4 team
First you need to know if you have a Dana 35 (M200) or Dana 44 (M220) rear axle.
Eaton E-Locker for the Dana 44 M220 rear axle:
https://www.northridge4x4.com/part/lockers/14234-1-eaton-d44-elocker-differential
You'll also want an install kit:
https://www.northridge4x4.com/part/...ana-44-master-overhaul-kit-w-d44-upgrade-rear
How are you going to actuate the locker? Are you looking to match the OE Rubicon switch set-up or something different.
For labor, figure around 4-6 hours for the locker install and then maybe as short as an hour up to 4-5 hours for running the wiring and whatever switch set-up you go with.
adeehalasa
Eddie
Rancho mirage
Jeep Wrangler
thank you sir for your prompt response . I am not sure what axle I have but I will talk to my mechanic about this. In your opinion charging $ 3500.00 for labor and part is fair?
I am not sure what switched I will have but The Rubicon switches will be a good idea.
Maverick909
I.E.
www.instagram.com
typically a locker cost about 1000 bucks plus the install kit with bearings, shims etc. its a couple hundred bucks. adding the switch and wire would be a couple hundred more. plus the label for all the install stuff. Depending on the shop maybe 2500 bucks would be my guess
QwikKotaTx
Houston, TX
2015 Hemi Ram, 2002 Porsche 911 Turbo
Seems a bit high unless they are swapping out the gears too but these need to be done in pairs. Front and rear diff ratio needs to be the same.
DesertsJL
Utah
JLUR
If it were me I'd install Eaton Truetrac's front and rear with the correct gears for your tire size and call it a day. No thinking, no messing around with wiring or plumbing, and they put way less stress on your drivetrain. Unless you NEED lockers, limited slips are the way to go.
Tech Tim
Tim
Poulsbo, WA
4x4 of all kinds
E-Locker - $1400.00
Install Kit - $300.00
Labor - $800.00 to 1200.00-ish
Total so far: $2900.00 on the high end.
The big Q is what they are doing for a switch set-up?
Something simple like an aftermarket switch would add very little $$$$.
An sPOD (which would be a great add-on and easy to install) could add $900.00+:
https://www.northridge4x4.com/part/switch-panels/bx-tsb-jl-spod-bantamx-touchscn
adeehalasa
Eddie
Rancho mirage
Jeep Wrangler
that is very helpful, I do have the SPOD operating the lights and the air compressor. I will ask if they can add the switch to it in order to operate the locker too.
rcadden
Ricky
Asheville, NC
Marketing
Glad you got great answers - this is a good community of really smart people.
HOWEVER, I do want to point out that the 2016 would be a "JK" model, and this is a "JL" forum. For the most accurate advice from people who own/know JKs, you might jump over to https://wranglerjkforum.net/
You're obviously welcome here, but just wanted to ensure you're in the right place as you get deeper into your journey. The JK and JL have some similarities (and many members here previously owned JKs), but they also have some big differences and it could get confusing for you if you're trying to work on your JK using JL tips.
BajaDesigns
Rock Sponsor (Level 1)
San Marcos, Ca
Non-Applicable
What style E-locker did you go with? SPOD is in-house with Baja Designs so the question can reach them much faster.
Best,
Brandon
adeehalasa
Eddie
Rancho mirage
Jeep Wrangler
Best,
Brandon
Hello Brandon, So far I am still looking. I live in palm springs CA , and I need to look for a local mechanic.
BajaDesigns
San Marcos, Ca
Non-Applicable
From what I have been told most SPOD units can run the E locker by just cutting out the E lockers relay from the harness and running the positive and negative into an inlet on the unit. The only time you will need to purchase something is if you are doing an air locker.
Best,
Brandon
