Confusing Misinformation About Diesel Regens
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Ammonia or not, it's not a good idea to breathe anything coming out the exhaust of any internal combustion engine.
ALeeL
Anthony
2021 JLURD
True, but the irony here is that the DEF is being added to reduce NOx which causes irritation and damage to eyes, throat, and lungs especially for the young and elderly— which is exactly what ammonia causes.
I have walked through one of our heavy duty truck service shops with several of these trucks with DEF running close by each other and it will start to irritate your eyes a little. Never had that issue before DEF.
Twisted10
Brandon
Western NY
2023 Wrangler 392 XR/2022 Ram Cummins
simple solution. ill catch hate if i say it tho.
so i wont. because im nice.
Deleted User 38384
All the more reason to DELETE DELETE DELETE!!! :LOL:;)
tugs
Rick
Florida / Maine
2021 JLU Diesel / Tesla X / Jaguar F Type
Don't conflate the ammonia slip problem with the DPF. The DPF does not use or need DEF. DEF is used to convert NOx in the reduction catalyst, a separate component (SCR catalyst) in the exhaust stream that performs the NOx reduction function.
Unfortunately, the exhaust temperatures required to regenerate the DPF are above the temperature that creates the problem of ammonia slip. There are (more expensive) catalysts that will lower the regeneration temperature but the regulators won't permit their use because it increases NOx emissions.
av8or
Randall
Oregon
2020 JLUR, 2023 Rivian R1T
FedEx-retired
Truck drivers make the best scientists.
Ask me how I know. 🙄
Wbino
NJ
I'm thinking you were going to say that every truck/car should be a EV.👍🤓
Wbino
NJ
The Tractor with the route I'm on at work today is doing a Regen, and I'm trying to explain to the driver why we shouldn't be down stacking beer in that plume of noxious gases. He's telling me it's just water vapor and nitrogen gas which for the most part is harmless to humans.
I was trying to explain to him that there could also be ammonia gas in there.
It's one of those things where the people selling the idea that regens are actually good for the environment, aren't telling you the whole story.
If you do a Google search for what the runoff of a Diesel Regen is, you might get an answer like this:
However if you've ever experienced firsthand the gas that comes out of a diesel's regen cycle, and you ask Google a different question that should result in the same answer, but doesn't, your search result might look something like this:
The simple answer is, not all of the ammonia from the urea / DEF process is going to burn off during the transference process. In fact quite a bit of it can reach your lungs if you breathe in this smoke. Don't believe me? Next time your EcoDiesel is regening, without breathing, go put your face over by the exhaust pipe. Not in direct path of the exhaust flow, but just off to the side will do the trick. The second your eyes start burning, and if you breathe in any little bit you'll start coughing... THAT'S AMMONIA!!!
If you're not aware of this, and you have a leak in your exhaust that is venting into the cabin of your Wrangler, You may not even know it, but the second year vehicle regens, you'll be wondering why the hell you can't breathe. In that case, the obvious choice would be to roll down the windows until you can stop the vehicle and safely get out of the vehicle until the regen process is done.
Be aware, that long bouts, or continued bouts of inhalation of ammonia gas, can kill you. It takes about 30 minutes of breathing in your Regen smoke before you'll actually receive a potentially lethal dose. Which if you're going to sit there and have trouble breathing for 30 minutes, you probably had it coming; Something in there about Darwinism.
After I showed this information to my driver, he decided he didn't care. So we agreed that he down stacks and I roll in.. 🤷‍♂️
Obviously there are going to be different amounts of ammonia for different vehicles:
If you have a clean and healthy diesel engine that has short passive regens often, you'll probably have more ammonia simply because there's less cleaning needed, but still the same amount of urea going through the system.
Whereas if you have a dirty engine that does mostly long active regions, you'll probably smell less ammonia in your exhaust. Again simply because you have a dirtier system, and more of that ammonia is getting used up and converted during the cleaning process.
:like: ;)
Is stacking beer Texas lingo for drinking lots of it?
