Clunk when turning over bump
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
2021 Jeep Wrangler WILLYS
U.S. Military Vet, Former Corrections Officer, Current Maserati Claims Specialist
So the tierod antiflop will make noise if you twist it like that. All stock JLs do that. Go to a dealership and you can twist the tierod on a new one to do that.
You can hear my track bar pop in this vid. It was tight enough under normal circumstances, but as soon as I started doing anything with the tires on different levels it would pop. Once I tightened it over torque spec it stopped. I am wondering if yours is a bit looser and when you pull into your driveway it is enough to make yours pop.
That very well could be.. just weird that I never heard it until now. But that could be the case
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
Well .. just as I thought.. tie rod and drag link had a slight amount of play.. so Metacloak heavy duty steering kit is on order.
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
Well... that wasnt it.. still does the clunk.. I planned on heavy duty steering anyway so at least thats out the way.. the search continues.. next order of business is to throw a torque wrench on body mount bolts.. make sure they are tight.. and replace rear track bar since that one is still stock.. see if thats the issue
sixspeed
Gregory
Arizona
2018 Wrangler Sport S JL
My mysterious clunk turned out to be my LOD frame sliders hitting the body bolt. Drove me crazy!
I still have a clunk. It is the tire hitting the loose fender liner. Forgot to get it fixed at the dealer last time. I may just remove it.
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
Mine is definitely metalic.. ill find it.. I hope.. lol
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
Check sway bar links for some reason I’ve found them loose on two occasions. It also makes a clunk noise
Ill check those.. I do jave synergy in the back and apex autolynx disconnects in the front
LukeDagny
Central PA
2021 JLUR
I had a clunk that was caused by the worn upper bump stop. The foam pretty much disintegrated. I was able to replace them without pulling a spring. I just jacked up one corner at a time to extend the spring.
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
Ill have to check that too..
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
Well.. metacloak steering and new adjustable rear track bar.. I can still get the clunk to happen.. the search continues.. im starting to wonder if something is just making contact back there when I turn over bumps.. only seems to happen when turning.. cant see any marks on springs or anything back there.. im confused
Tbogo
Tom
TX
2022 JLUR XR, 2021 Raptor 801A
Good luck is right. I've had a popping/clunk sound on mostly on righthand turns going up inclines at less than 5 mph. I had it looked at by the dealership and was misdiagnosed as end links. They can not find the problem. I have also replaced all shocks and SS. No fix.
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
Its annoying.. it sounds like something is making contact but I cant see any marks.. I know the track bar hardware is undersized from factory and has play in the holes but it never made this noise before. I ordered some aftermarket hardware thats supposed to address the undersized factory hardware and will install that but I dont have much hope thats the issue.
Tbogo
Tom
TX
Yes very annoying! Do you have a recording of the sound by chance? The video you posted previously has been deleted. I am going to try and record the sound mine is making.
Twisted Patriot
Twisted Patriot
Michael
SE Michigan
I dont anymore. Ill have to take another one
