Cleanest Phone Mount Solution
Horsemover
Jamie
NW PA
2021 JLURD / 1997 TJ 4.0
stuzor
Jeep XJ
Unfortunately as I posted before the mount is no longer being sold to mount this to the grab bar handle. Kudos to sleepovr with the recommendation for cmm offroad. I think I will go with bulletpoint for everything else with the cmm offroad grab bar mount.
To answer your question this is a universal adaptor for 20mm to inch. What you need is something like sleepovr recommended from cm offroad since bullepoint is having issues there plus this
https://www.bulletpointmountingsolu...ar-arm-and-universal-phone-mount-holder-combo
Elk666
Franck
QC
2021 4XE
thank you
the cmm and bulletpoint combo seems to be what i'm looking for :like:
R3TRO
Pasadena, CA
'20 Jeep Willys
Film Industry
Well, my mount came today from Offroam...I was apprehensive about spending that much on a mount....but it performed flawlessly today on the trail. Lots of rock bouncing and washboard roads...it is a rock solid mount. I'm going to add a grab bar mount for the small tablet but this worked great today with a note 10 in an otterbox. Kept my maps right where I could see them.
The other huge plus...it doesn't block the AC vent...very important in Arizona!
Forgot the link...
https://getoffroam.com/collections/jeep-products/products/jeep-wrangler-gladiator-phone-mount-kit
I too went this route. Does not block vent and I can't imagine my phone ever popping out! ONLY one issue I have with it is that the spring is so stiff that I had to develop a technique to insert/remove the phone so as to not move the arms. Otherwise doesn't matter how tight I screw her down, the leverage of putting phone in/out moves the arms ever so slightly and after a few days you have to reposition.
Ct_Formula
Orange Ct
2021 Rubicon JL, 2011 JK Sahara
Self Employed
Well that was a quick $180 dollars for driver and Passenger phone mounts. Hope they work as advertised.
MudHorn4xforLife
Jonathan
Tennessee,USA
2021 wrangler 80th Anniversary Edition
I just bought & combined these two. Total is still less than the other rail systems. I guess time will tell.
Jeep Wrangler JL Cleanest Phone Mount Solution 010DD15C-85DA-4B88-8EA8-F863FBB087DC
Jeep Wrangler JL Cleanest Phone Mount Solution AB38A90F-C137-4ED1-9407-C7810EE901A2
AmarilloJLU
Jon
2021 4Xe Rubicon on order
I just added this setup to my 4Xe Rubicon. I have an iPhone 12 Pro Max with the magnet on the back that uses the MagSafe chargers. I bought the first part of the setup that comes off the grab handle from Bullet point mounting solutions. And then I found the last piece on Amazon. That piece holds the MagSafe charger on with an adhesive pad and the Wrangler has a USB-C input. This holds onto my phone (which is very large and heavy) very well with the magnet part. If you have an iPhone 12 with the magnet built into the phone this works very well. You have to purchase the MagSafe charger sold by Apple. It charges your phone while mounted which is a huge bonus since you don’t have to plug a cord into the bottom of the phone.
Jeep Wrangler JL Cleanest Phone Mount Solution A4974045-0613-4474-A88C-37F779E4F419
Jeep Wrangler JL Cleanest Phone Mount Solution 6AC2BF6B-EF29-48A8-BC4A-3A2FD5049914
Jeep Wrangler JL Cleanest Phone Mount Solution 2000EC68-0FC3-43D1-BEB4-DD8B2DD7A755
Jeep Wrangler JL Cleanest Phone Mount Solution 92203CC5-CAEB-4DFF-A600-93CE229296D1
Jeep Wrangler JL Cleanest Phone Mount Solution CE6420B9-4A80-40A8-8FBD-F2E44E4D3342
Jeep Wrangler JL Cleanest Phone Mount Solution 3B44D688-B5F9-489D-ADD1-171FEEED6D45
Nole_Dynasty
Seminole
Charlotte, NC
2020 JLUR
But then you don’t get Apple CarPlay functionality?
AmarilloJLU
Jon
That is true, but you still have the ability to use Apple Carplay as I will explain. I have found that I don't use the Apple Carplay function much. If I use navigation it is through the UConnect, and I also have XM Radio so I don't need to use an app for music. With this mount option you still can use the magnet to mount the phone, unplug the USB-C and you could still plug in the Lightning cable into the bottom of the phone to utilize the Apple Carplay features with no issue through the regular USB port. In the end this has been a great phone mount solution, and in the end it is very versatile.
itsooh
NJ
2014 BMW335i, 2021 JLU Rubicon
Hello,
Looking phone mount options for new JLU.
I like 67D phone mount but I am not sure about their track system
To me, Ram track is cleaner.
So, I am wondering if 67D track ball can be fit with Ram track.
Does anyone know?
Crawldad
Hagerstown, MD
'21 2dr wrangler rubicon, '18 Ram3500
