Clean tires help
aldo98229
Aldo
Bellingham, WA
Market Research
  1. Spray Bleche-Wite on the tires, let it sit for a few minutes
  2. Scrub with a hard plastic bristles hand scrubber
  3. Hose down with plenty of water
  4. Then spray on some No Touch Tire Care. Let it sit for another couple of minutes
  5. Rinse thoroughly
Tires will look like new.
Jeep Wrangler JL Clean tires help 831A7EF3-851A-4100-8F19-6AF1C5A3B0FE
Jeep Wrangler JL Clean tires help E946C35D-318F-4644-AD5B-8DEF173ACF86
BXFXJeep
Toronto, ON
2021 4xe Sahara
Commercial or home? The home use ones are useless, it doesn't clean mine, I go to the self car wash to use theirs.
R4D4R
MA
JKU
I dont know why you all are recommending some BS hacky solutions. Just go to Autozone or wherever and get some foaming tire cleaner. That dirt just comes off.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
Dawn Power Wash and a scrub brush worked wonders for me. Then follow up with your favourite tire shine.
There’sOnlyOne
Greg
NW Georgia
2021 JLUR
If this stuff doesn't clean them I'll be very surprised. Safe for wheels also. Or Simple Green. But I'd go Brake Buster. SG pending dilution ratio can stain your wheels. A good tire brush also. Is that mud stain? If so it shouldn't be so hard to remove.
You can get this from Amazon if that works better for you or multiple detail websites or the manufacturer themselves.
https://psdetailproducts.com/products/brake-buster-doubleblack-collection
whiterubicon
Knoxville, TN
2019 JLU Rubicon
You can also spray Simple Green on the tire and the follow with Meguiars Hot Wheels. Seems to work for me on the Jeep. You also need to make sure that you are using a stiff bristle brush
nositting
PA
19 JLUS
303 does the trick on tire bloom. ever if it fails for your tires, you can sill use it on the dash, console, rubber, fenders, bumpers, etc.
elf883
steven
NY
2024 jlu willys anvil
stationary engineer
Dryver
NE Ohio
2021 Wrangler 4xe "Bridgette"
  5. Rinse thoroughly
This
ForgottenTaco
CT
‘23 Sarge Green JLU Willys
I spray on some Meguiars hot rims wheel and tire cleaner, scrub, rinse, dry then spray on some Mequiars hot shine tire shine. They have a few different ones depending on how shiny you want them. Spray it on, let it sit for a little bit then wipe off the excess. I like the product because it actually keeps that crud covered up. Don’t like it so much because of how shiny it is.
https://www.meguiarsdirect.com/meguiars-hot-rims-wheel-tire-cleaner-24oz.html
https://www.meguiarsdirect.com/meguiars-hot-shine-high-gloss-tire-coating-15oz.html
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
What always works for me is Armor All foaming tire dressing. Now here me out, because I detest shiny, greasy, wet looking tires.
Drive to a wand style/quarter car wash. While your tires are still hot, spray this stuff liberally on your tires. You will be able to see it dissolve the brown film. Then, wash your tires well. When done, the tires will be a nice satin black with no shine.
To keep it from happening again use Simple Green on your tires prior to washing. Never use any dressing, shine or similar “detail” product. This makes some people unhappy to hear as for some reason many love to put that shit on everything. It will ruin everything you put it one.
303 Aerospace is water based and wont ruin plastic or rubber. Use that if you must, just understand that it doesn’t leave things shiny and wet looking.
Dryver
NE Ohio
Fun story. My dad was always a stickler about his cars. One day while he was at work, someone was demonstrating (what was then Westley's) Bleche White and used his car tires for the demonstration. He always used it from that point on, and now so do I. Not nearly as often as I should though... ?
JJ_WA
JJ
Puget Sound, WA state
2002 Dakota, 2017 Cherokee, 2023 Willys XR
Retired US Army, Higher Education
Another vote for a simple power washer. Mine is a hand-me-down from my mother's estate. It's about 12 years old and is very basic. I used it this weekend (no soap, just water) for the same brown coloring. Took it right off and the tires now look very good.
garykk
Gary
Southern NM
2022 JLURD
I use Wesley’s Bleche-White and a stiff brush followed by 303.
don’t let it dry on the tire.
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
