Cell phone mount recommendations
Marine2146
North Carolina
2023 Grand Wagoneer 3 series, 2022 Rubicon 392
I went with ram mounts products. No holes to drill and extremely sturdy. I didn’t mind loosing the storage on top of the dash as I don’t like the reflection of junk on the windshield. I needed a phone holder to accommodate different size phones and cases without adjustment. I mounted it upside down to keep it low and it’s much easier to put the phone in that way to. Just put the bottom of the phone in, press down and in then let it go back up. It doesn’t block the infotainment screen or the air vent. The dash mount uses T-slot accessories.
Jeep Wrangler JL Cell phone mount recommendations D8219ADE-9E74-42FD-9CD6-58AD050D74D5
Jeep Wrangler JL Cell phone mount recommendations 5F09892D-274D-4A6E-A744-6D9502CBCAED
FinnCustomKnives
Woodstock, GA
2021 Wrangler Rubicon Ecodiesel
We went with the 67 designs trail rail for phones/go pro mount. Wpngear for pistol mount. M.O.R.E. for ARB dual compressor mount.
Literally can't complain about any of them.
Az-jewel
Julie
Southern Utah
aquajeepgirl.com
‘18 JLU Sport S
SAHM
I LOVE my OffRoam phone mount! It attaches to your vent and stays put despite lots of off-road bumps!! I have definitely tested this one!? You should check it out! http://www.getoffroam.com/
Jeep Wrangler JL Cell phone mount recommendations 45570344-2C10-4A45-89D3-C24B9AC23B44
Jeep Wrangler JL Cell phone mount recommendations 824CB6C4-B6FF-4FFD-8FA5-B9DC5F56B2FD
M@tt C
Wadsworth, OH
2022 Unlimited Willys, 2022 Gladiator Sport S
Another vote for Offroam. I don’t like stuff on top of the dash, so the Offroam did the trick. Have the same in my wife’s Gladiator and she loves it.
Jeep Wrangler JL Cell phone mount recommendations 03D16A62-4C6E-49B9-B6C8-BA117244F74E
Zenmaster238
Jonathan
Louisiana
2022 Firecracker Red JLURXR
Do you have a pic of your wpngear?
Themistocles
Virginia
'03 Ram 2500 Cummins / 20 JLURD
I put mine on the left side on the pillar. I like it because it is at eye level so I don't need to look down when looking at maps or similar. It also doesn't block any view, as it is just covering the pillar. Also, as it is magnetic mount I just pop it on as I open the door. Also I ran constant power under the dash and up to just behind the phone so there are no cords running anywhere. This is one of my favorite mods I have done so far.
Jeep Wrangler JL Cell phone mount recommendations Phone Mount 1 (2)
Jeep Wrangler JL Cell phone mount recommendations Phone Mount 5 (2)
Jeep Wrangler JL Cell phone mount recommendations Phone Mount 2 (2)
Signguy71
jim
Ohio
2019 traihawk
I have the same setup but need to order the arm. Which arm did you order?
Thanks
Twowheels19
PA
‘22 JLURD
I opted for the 67 Designs mated with an existing Quadlock charging base off of the cycle. CMM grab bar ball mount for passenger options. I plan on changing out the sloppy old kinked cable sometime but it still works for now.
Jeep Wrangler JL Cell phone mount recommendations 42A1EA0E-F78F-4F81-8587-3E0372036CEE
kah.mun.rah
Merenkahre Jr.
Duat
I have both the 67 Designs and the Bulletpoint. Overall either are great options. The only issues I ran into with each:
With the 67 Designs the ball became loose and had to be retightened...which isn’t fun since it has to be removed and tightened from underneath after it is screwed and 2 sided taped to your dash.
With the Bulletpoint the adhesive that holds the pads that grip the cellphone broke loose in the direct sunlight and the pads just slide off. The good news is that if you have a phone case the pads arent really necessary anyway.
Summary, use the Bulletpoint ball but the 67 Designs mount. Haha.
Deepsea1212
Sam
JLU WILLYS, JLURD
I really like this setup but they changed the grab bar on the 2022 and there is no longer an exposed bolt so the ball mount wont work? I looked at the CMM website and it says 18 to current JLs so must be an oversight. Currently looking for another solution to attach a ball joint to the grab handle if anyone has one.
I have a 2022JLURD and have exposed bolts on the grab handle. Maybe the Sahara or another model has leather wrapping the handle but my 2022 has the exposed bolts. I ordered the 67designs driver model but felt it was too close to me so I ordered the passenger side mount and the grab handle ball to see which I like better. They haven’t come in yet.
