CavFab Installation Experience
[DELETED USER 82058]
Alabama
2022 JL Rubicon 2-Door
I think first and foremost, do you want to go thru the trouble of painting your own or want it to come powder coated already? I think answer that and go from there.
I would take it to powdercoat.
Alabama
The top choices are Cavfab, Motobilt, Rusty's, and Teraflex.
I would only ever opt for a seperate hinged carrier and rear bumper. My thoughts and reasoning:
The rear bumper is hard mounted to the frame, whereas the body is soft mounted to the frame, via rubber isolators, to allow independent movement. When adding something that bridges 2 independently moving points, like a rear bumper mounted tire carrier that also attaches to the body, an extra level of stress is introduced. Not only does the single cantilevered pivot arm have to support the weight of the carrier and spare, it's also going to try to limit the body from moving on its rubber mounts. Inevitably, something has to give, and it will. It's just a matter of what gives first. That's why the only bumper mounted carriers that are quiet, are the ones that haven't been on the Jeep for too long. Again, just my thoughts.
Rusty’s and Motobilt are within the state. I work 10 minutes from Rusty’s.
These reinforcements just seem to have very invasive installs as opposed to a bumper with swing away. OR…I could just say screw it and delete the spare. Why in the hell Jeep didn’t consider a 35” tire and wheel combo would weigh over 85 lbs is beyond me.
kdiff
Kurtis
Castle Rock, CO
392 Rubicon, Sprinter
The feedback on the install from everyone is super helpful. I was planning on buying a CavFab tire carrier this week or next but I’m going to see where this thread goes. I don’t mind some work on the install but having to buy washers to shim things seems… a bit lacking in design.
Edit: How does Evo compare? I have a friend with a JK that swears by them.
j_stew762
Jake
Southern, IL
2020 JLURD
Ironic, but I just started installing my Cavfab tire carrier today after getting it back from being painted.
I thought I was losing my mind when I couldn’t find basic install instructions (glad to check here and confirm it doesn't come with any). Pretty straight forward though if you pay attention to what bolts come out of the factory carrier, and what factory bolts get re-used.
The hinges do NOT come with shims, or at least mine didnt. A little frustrating at first.
I dont have my 35” spare and aftermarket wheel on yet, and I’m sitting about 1/8 inch high on the latch side. This should settle once I get my 100lb wheel/tire set up put on.
Jeep Wrangler JL CavFab Installation Experience F18C3945-C5B9-4755-B1D9-5BB696B97AEB
Jeep Wrangler JL CavFab Installation Experience 58E83963-425B-4E23-9977-6C2C85069338
72Blazer
The Real South Texas
72BlazerCrawler 72Blazer12V 88SBDuramax 18JLUR
SLP
Mine came with spacer and super easy to install after I got it figured out. EVO is overpriced IMO.
72Blazer
SLP
That’s sexy color matched
ChuckQue
Charles
www.stayreadyoutdoors.com
2022 JLURD
Owner of Stay Ready Outdoors
design is decent. Is it the best? No. But why am I going to pay $1400 for a Teraflex carrier? How many times am I going to remove the spare to justify the cost difference? In all honesty, I just removed my Teraflex tire carrier to replace with the full CavFab tire carrier and the Teraflex wasn’t the fastest and still required tools to remove. Heavy? Which carrier isn’t? I guess for most females or girly men, it would be considered heavy. I did the install on my previous JL on my own.
Huh? What tools are required to remove the spare tire from the Teraflex, aside from a lug wrench?
So you already had the Alpha mount from Teraflex, but removed it to replace it with the full carrier from CavFab? I assume you are selling or sold the Alpha, but I don’t understand why you didn’t just keep it and finish off the setup with the carrier. I first bought the mount, then eventually bought the carrier. Both went on with zero drama and almost no adjustment needed.
CavFab_mfg
Summit Sponsor (Level 3)
CavFab
Wildwood ga
2018 jlur
Aftermarket Jeep Product Manufacturer
I'm actually glad this thread came up.
we were a very small company (3 people) that grew extremely quickly, and currently growing significantly. initially we never really had the resources to develop extensive installation instruction manuals.
along with the application parameters that arise when many more wheel and tire combos and other accessory compatibility comes into play.
We recently bought a 2023 (i goofed and put 22) ecodiesel so we can re-visit the install procedure and thoroughly document the process with video and produce an installation document for all our products to be visible on our website.
I totally get the frustration some of you have experienced, and i really apologize about that.
we hope the process documentation that we are investing into our products for you guys with this build will help you tremendously.
we wont necessarily be clogging up the thread with the steps, but we will have formal documents posted on our website.
check it out below and we really apologize for not being able to produce this sooner.
(10) CavFab 22 Diesel JLU Shop Build | Jeep Wrangler Forums (JL / JLU) - Rubicon, Sahara, Sport, 4xe, 392 - JLwranglerforums.com
Jackalope
Jackalope
Chicago - NW Suburbs
2019 Rubicon JL2dr
Small Business Owner
Couple of thoughts:
Nice paint job on the CavFab, looks like a good match.
I would think your 35" spare and aftermarket rims would fit on to your lug plate just fine. I think most folks are investing in new rims. I decided to keep my stock OEM rims and they did fit without modification.
You said you are "sitting about 1/8 inch high on the latch side" but it looks pretty good to me. I thought the same thing about my setup, but I found that once those hinge bolts are snugged tight, that tailgate isn't dropping at all.
72Blazer
SLP
What tools are required to remove the spare on CavFab? Allen wrench and socket, same as the Teraflex.
Inquiring mind wants to know. I purchased the current JL used in December. Instead of shelling out another $800 to finish off the Teraflex setup, I went ahead and started the install of my previous CavFab carrier I removed from my previous JL I sold in 2021.
ChuckQue
Charles
2022 JLURD
Maybe I’m missing something, but I only need a lug wrench to pull the spare on my Teraflex. The third brake light has a quick disconnect on it, no tool needed….
I mean, if you already had the CavFab then sure it makes sense in that scenario. Otherwise I would’ve just popped the extra $200 to finish off the Teraflex.
Again, nothing against CavFab it just seems there are issues with fitment, plus I think the Teraflex looks better. That’s just preference though.
72Blazer
SLP
I had to use an Allen to remove the third brake on mine as it was over tightened.
$200? Maybe I’m missing something?
https://teraflex.com/jl-alpha-hd-hinged-spare-tire-carrier-kit.html
ChuckQue
Charles
2022 JLURD
