Caster help and opinion
jadmt
jeff
montana
oh yea! I know I put wood under the tires and did it!
but was it 100% level? if the surface was sloped the wood would be sloped equally unless you used different wood thickness to make up for the slope of the surface. Some places will do an alignment check for free. my local les schwab used to do that.
Roky
Roky
I’m not sure on the caster I have pictures currently running. I don’t know if they are off.
-2.5 lift
- falcon 3.3 shocks
- metal cloak 2.5 springs
- metal cloak tie rod bar and tie rod
- metal cloak drag link
- yeti HD updated bushing. Track bar
- yeti sector shaft brace
- Baja boss 35x12.50r17 MT D rated.
Make sure you’re sitting level as mentioned, put angle finder on the flats of the diff….
Jeep Wrangler JL Caster help and opinion IMG_8363
90 degrees or 0 degrees equals 6 degrees caster….if the needle is behind the 90 or 0 then you have less than 6 degrees if the needle is ahead of the 90 or 0 then you have more than 6 degrees…….here’s mine, I’m running about 5.9 ish…..
Jeep Wrangler JL Caster help and opinion IMG_8361
Don’t over think it, the number isn’t as important as the way it handles…. Best thing to do is check it see where it’s at, drive it, if it wanders then increase it, if it drives good leave it…..This has the biggest impact on wandering, the dead spot in steering wheel is likely in your steering box….dead spot and wandering are two different things caused by two different factors…..
Blackdew
Blackdew
Fred
Ohio
2020 JL
yes! I placed it on both them holes on each side and underneath the both knuckles.
I’ve done all my suspension and this a bit of a learning curve lol. Any advice will be helpful! Also read to undo all the bolts and not to take anything off and always do one at at time.
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
ONE AT A TIME on the swap!!! Do it on the ground. Chock the tires and roll it to get the bolts to line up.
Any reason to loosen the LCA bolts? I am wondering if I just pivot the axel back to adjust caster via the UCA's and LCA's are still torqued to their specs, the bushings would bind?
Of course I am naturally overthinking this, most likely
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
You are running aftermarket front driveshaft?
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I don't know that'd Id worry about such a small bushing rotation, but you certainly could if you are running stock style bound/adhered bushings.
It won't matter with an unadhered aftermarket joint anyways. The MC Duroflex I assume the OP is using rotate freely.
Blackdew
Blackdew
Fred
Ohio
2020 JL
I was able to install the control arms but when I was under it I noticed my ball joint. Could this be a lead to my problems
Jeep Wrangler JL Caster help and opinion IMG_6816
Nokones
Kenny
Sun City West, AZ
It is probably past the start of your problems.
Blackdew
Blackdew
Fred
Ohio
2020 JL
Trying to pin point this dead spot. Outside the dead spot the steering is extremely tight.
Blackdew
Blackdew
Fred
Ohio
2020 JL
This is what it measured out to be. I did at the diff where the two holes are at and under the steering knuckles. I have an extremely bad shimmy over bumps on the highway.. if I try to correct it, it gets worse and feels like I will flip the Jeep unless I correct slowly. No death wobble at all or vibration.
Jeep Wrangler JL Caster help and opinion IMG_6901
Jeep Wrangler JL Caster help and opinion IMG_6899
Jeep Wrangler JL Caster help and opinion IMG_6898
Jeep Wrangler JL Caster help and opinion IMG_6900
Jeep Wrangler JL Caster help and opinion IMG_6902
failsafe306
Tulsa
2022 JLUR 2.0
Mine does that. Never thought anything of it tbh.
GATORB8
CLT NC
Talking about the sleeve/spacer? There is supposed to be a gap there.
