Bumpsteer, Caster, and Geometry Brackets
Kum4224
Kumail
Los Angeles, CA
2018 JLU Sport
After running a mopar lift with stock steering components on my JLU Sport for 4 years, I finally got around to getting some adjustable front and rear trackbars by Synergy and some rancho geometry correction brackets to improve wander. I got the brackets installed on the top most hole (the lowest setting) and utilized my Mopar extended LCAs with it since I don't have the factory ones with me. The Mopar ones are only about 1/8" longer eye to eye than factory.
Just got it back from the shop and my alignment shows castor at 7 & 6.8 degrees. Steering does feel pretty heavy but not crazy heavy. And on speedbumps or driving through intersections that have a bump, I do see some bumpsteer. Prior to brackets, my castor was at 5.5 & 5.4 with the extended arms.
Is my castor too high? Should I be trying to find factory arms to help bring it down a bit? Jeep drives really steady, just sometimes I feel the heaviness is on the higher side. And im wondering if the bumpsteer is happening from too much caster or something wrong in the trackbar install.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
If I remember correctly, castor angle seemed to have a sweet spot around 6 - 6.5 degrees. This may vary depending on how much lift. I don't know if that's causing your occasional bumpsteer. I personally would prefer a quality set of adjustable LCA's vs geometry brackets & fixed LCA's. Especially if its needed to go back and re-adjust the castor angle.
