Geometry correction brackets JL
Hd088
Hassan
Brooklyn ny
Jeep wrangler JLU 2021
Hi I'm about to inshall aev 3" high capacity springs coils with aev shocks and set up I'm wondering which geometry correction brackets I should get either aev which cost 329$ and rancho geometry cost $210 some say rancho geometry correction brackets are better than aev if I'm running aev liftkit which one u guys recommend help would b better so soon enough I can order one thank you
Roky
Roky
Doesn’t AEV come with their own included? Or did you not buy the kit, just parts individually ?
Hd088
Hd088
Hassan
Brooklyn ny
Doesn’t AEV come with their own? Or did you not buy the kit, just parts individually ?
Long time story I ended up not getting geometry correction brackets with kit I had 2021 jl with liftkit wanted to change for aev ended up sold the 2021 got 2024
Hd088
Hd088
Hassan
Brooklyn ny
Spend the $$$ and get adjustable LCAs. Find something from market place or the like to keep costs down.
Which brand and might b pricy bit at the moment
Roky
Roky
Gotcha, if you’re gonna be off-roading it, then I’d recommend Metalcloak but if it’s a pavement princess, then it really doesn’t matter……
TXSquid78
2024 Willys 4xe; 2005 Corvette
Coin toss. Teraflex, MC, Evo are all well known and recommended brands. Not sure of the cost vs. the geo brackets. Assuming that being in Brooklyn there wont be much offroading or at least not regularly.
Northridge4x4
Summit Sponsor (Level 3)
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
Hd088
Hd088
Hassan
Brooklyn ny
D
Definitely not princess actually do off roading its a overland build thank you
Hd088
Hd088
Hassan
Brooklyn ny
I'm actually always out of Brooklyn with jeep mild off road camping overlanding n stuff I will look into
Hd088
Hd088
Hassan
Brooklyn ny
Get Geometry Correction Brackets. They help get lower control arm geometry back closer to stock.
Rancho Geo Brackets are good stuff and the price is right:
https://www.northridge4x4.com/part/...ncho-performance-geometry-correction-brackets
The JKS Brackets are a couple dollars cheaper, but I haven't installed them personally, so can't tell you if they are as good as the Rancho ones:
https://www.northridge4x4.com/part/control-arm-mounts/6201-jks-control-arm-correction-bracket-kit
Sounds great I did see rancho geometry correction brackets price is decent if u compare to aev I don't mind spending reason I asked if rancho give me the same reu
driving in NYC is kinda like offroading.
😅😅 thank God I don't go into that part of nyc where I'm at its decent good🙏
c20040215
Leon
Indiana
Adjustable LCA and brackets achieve different things.
Hd088
Hd088
Hassan
Brooklyn ny
I was thinking for now I can Stick with geometry correction brackets with aev liftkit maybe in future when the money is bit better I will upgrade
c20040215
Leon
Indiana
Among all the drop brackets for JL, the two I would avoid are AEV and Rough Country. AEV is thin stamp steel, and RC is not even welded together. Everyone else makes pretty much the same with 3/16 steel welded together. Some might have better welds than others.
