Cam Sensor Fault
Rusty Shovel
Rusty
Utah
2002 TJ, 2005 TJ Rubi, 2012 JK Rubi, 2023 JLU Rubi
My 23 Ecodiesel is intermittently throwing a check engine light. The error code resolves to a cam sensor fault.
The engine seems to idle rougher than usual for the check engine light is one, but then it seems to resolve itself.
the dealer Recommended keeping the Jeep for a full diagnostic. They kept it for 10 days (!) and couldn’t replicate the failure.
so what now? Has anyone heard anything about this? My Jeep has 16k miles.
BDinTX
Dallas, Tx
kosinar
South Carolina
2020 Black JLUR 3.0 EcoDiesel received 3/6/20
I started getting it on my 2023 Gladiator EcoDiesel Monday this week. So far it came on twice and it was gone by itself next morning. Got appointment to check it but it is few weeks out.
bobholthaus
Bob
St. Louis, MO
2023 JKURD AEV JL370; 2014 GC Overland Diesel
Technology Integrator
Any resolution here guys? My 2023 diesel with 8000 miles threw this code twice this week, and I leave for Colorado tomorrow morning (for a week long, 2500 mile trip that includes all of the trails around Telluride). It’s at the dealer right now for the second time this week. This code was thrown in the last few months and was stored, but resolved itself. I took it to the dealer 2 days ago and they reset it and it came back last night, which may be indicative of the sensor actually failing this time. Fu** my life. This vacation is needed and these trails are a 20 year bucket list item. Do I go and just pray? I’m thinking I probably have to. Dealer said sensor is on backorder until ā€œat least 08/29ā€.
  • Sad
Reactions: DGT
SparkleTooth
Earth
Stellantis SUCKS
Here's what Claude the AI has to say about it:
  • Inspect sensor wiring - Make sure the wiring to the cam sensor is intact and securely connected. Look for any rubbing or damage that may interrupt the signal.
  • Check connector - Unplug the sensor connector and inspect for moisture, corrosion, bent pins or damage. Clean with electrical contact cleaner and reconnect firmly.
  • Replace sensor - The cam sensor itself may be faulty and need replacement. Use an OEM Mopar replacement part for best results.
  • ECU update - There may be a software calibration issue in the engine computer. Have the dealer check and install the latest ECU update.
  • Cam timing - If the cam timing has jumped or slipped, it can confuse the sensor. Verify cam timing with the dealer service department.
  • Oil leak - An oil leak near the cam sensor can damage it or interfere with its signal. Have any leaks addressed.
  • Crank position sensor - A failing crank sensor can potentially affect cam sensor operation as well. Have crank sensor diagnosed.
If the light comes on consistently, have the dealer scan for any related fault codes to help narrow down the specific cause. Intermittent issues are commonly wiring or connector related.
bobholthaus
Bob
St. Louis, MO
Thank you for this. I will send this to them now; I really appreciate it.
I’m taking the trip regardless. Service manager said it’s likely just intermittent anyway; I have not experienced ANY performance issues to date. ā€œSometimes Joel, you just have to say, ā€˜what the fu**ā€™ā€. (Risky Business)
bobholthaus
Bob
St. Louis, MO
You guys ready for this? I have a 2014 Grand Cherokee Diesel I’ve owned since new. And the 9 year old cam sensor in that is the exact part number as in my 2023 JL. So yes, the dealer took a 9 year old part out of my GC and put it in my new JL today to make the light go off. Voila. I’m shaking my damn head. It pays to go to the same dealer for 11 years now!!
JAMM
Kentucky
2023 Rubicon Unlimited
I just purchased a (new) 2023 Rubicon on Friday that already had the fuel pump recall completed. It threw the P0341 and suffered a leak in the fuel line the same day. Dealer reset the code and fixed the leak. I picked it up on Saturday and it's thrown the code again today (and stalled once). I am taking it in tomorrow for them to look at it again.
I really like the diesel, but I am supposed to have 3 days to change my mind on it. Has anyone had luck with resolving this, or should I look into what my other options are (I really don't want to).
Thanks in advance.
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
Thanks in advance.
Sounds like they didn't fix it.
JAMM
Kentucky
Well, not for me at least. Have you been happy with your eco diesel Dave? I am leaning towards just seeing it through.
bobholthaus
Bob
St. Louis, MO
My CEL for that code continues to go on every couple of weeks. My dealer doesn’t seem to know how to fix it. I’m considering trying another dealer. It’s frustrating. Otherwise I love my diesel.
JAMM
Kentucky
Thanks Bob, will post an update on what the dealer says later today.
bobholthaus
Bob
St. Louis, MO
I have owned a 2014 Grand Cherokee Eco since new; it’s 9 years old now and has 118,000 miles on it. It’s currently in the shop; there’s a recall on the inner part of the camshaft sensor for that engine (which is the Gen 2). I can say this, and I bought my 2023 Rubi Diesel and sent it to AEV to be upfit (I’ve got about $95k in this Wrangler now): I’m not sure I want to own a Jeep diesel that isn’t under warranty. My Grand Cherokee diesel has been in and out of the shop repeatedly over the years for engine stuff. The CEL goes on and off in that vehicle too. I LOVE the power and the gas mileage, but these ARE NOT the most reliable of vehicles. My friends thought I was crazy to buy another Jeep diesel. But I do love them that much. I also have already purchased the 8 year 125,000 mile warranty for my new wrangler. That my two cents. My best advice to to buy the warranty!
I had a 2012 Wrangler with the Pentastar, for 10 years. It wasn’t the most reliable Jeep either. My GC is going to my son next week for his 16th bday; I’ve never just owned a single Jeep as my daily driver (I always had the other one as a backup vehicle). Anyway, time will tell if my Wrangler is reliable enough as a daily driver. I’m waiting on the fuel pump recall on both of these Jeeps; the Grand had an ETC (elec throttle control) light come on three times a few weeks ago, putting me into limp mode. The dealer has had that car 26 days with an exhaust leak and the ETC and it fell through the cracks (dealing with the general manager this morning on that). I’ve been an exclusive Jeep customer since 1998; but with my current batch of diesel issues happening on both my Jeeps, I’m slowly losing faith in the brand. My dealer has been great in the past; but this 26 day stretch this time is unacceptable and this morning I’m shaking the trees to get this car back to give to my son. They said they can’t find any stored codes on the ETC because the battery went dead. It’s one thing after another. All in all, I still love these vehicles, but it takes a lot of patience.
Wrangler man
Howard
Palm Springs
2020 JLUAD
Thanks in advance.
If this is the dealership that did the fuel pump recall service I would definitely use your option give it back and go elsewhere. If it was me I'd find one that doesn't have issues. It may not be easy but they're out there. Then I would start shopping for a future service dept. A very competent service dept. One that has at least two certified diesel mechanics. They've already demonstrated their incompetence. They obviously did something wrong. I would venture to say there was no problems with the fuel system beforehand. I'm standing with the few that have said I will seek the recall when the time comes for it. Mine for the moment is running flawlessly last thing I want to do is drop it into an incompetent service shop. Nowadays seems to be the norm. It's the fallout that started in 2020
