Calibration after 37s? What else?
Mikeyut3
2020 JLUR
Have JLUR with mopar 2” lift. Going to 37s (Bfgs) this weekend. Do I need to re-calibrate and how easy/hard is this? Anything else I need to do to do this right? Thx!
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Well the tires may not require as high of psi as stock. The tazer is nice especially with the rubicon. Can turn off auto start/stop, lower tpms threshold, sway kill is nice and many other functions. It also sets your tire height and gets speedometer correct.
Your axles may end up shifted side to side, which can be corrected with an adjustable front track bar and rear track bar bracket. It may feel just fine and not shift much, but acceptable shift is up to you. I have the mopar lift with corrections and running 37s and very happy with it.
Jeep Wrangler JL Calibration after 37s? What else? 736522F1-0C41-435D-969F-44CFEFE593D1
Mikeyut3
Mikeyut3
2020 JLUR
Very nice. Whst size wheels are those?
Mikeyut3
Mikeyut3
2020 JLUR
17x9+12 offset. 37x12.5 mastercraft mxt tires. Use it too.
Amazing. Back to the calibration. Is tazer best and do i need to buy it or can someone who has one just “flash” me? I know there is a lite versus regular. And is there any advantage to owning it or keeping it plugged in?
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Personally with the rubicon I would get the full for around $300 I believe. I can’t remember exactly. I’ll post a comparison shot here for you to see. If you off road much the sway kill function allows you to disconnect sway bar in 2wd and at any speeds. Factory is in 4wd only and only up to 18mph. Then when you run larger tires your psi will be around 30 vs stock at 37 so may have tpms light on all the time. Tazer allows you to change the light threshold to 25 or whatever you desire so your light isn’t always on. Also does a lot more, but those are the main ones I use along with start/stop kill. The light does some just have to see if you’d use enough of the extra ones on the full/mini.
Jeep Wrangler JL Calibration after 37s? What else? 57C90D88-4283-4A95-9FFF-308C56E666BF
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
You’d have to own it as well as it vin locks.
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Nice pics...how many bumpstops are you running and how much do your tires rub wheelin when flexed up and turning?
Just the bump stops that came with the mopar lift. Think they are about 2 inches front and back. Can measure them if you want. Minor rub in the rear inner fenders and if I have passengers it will rub a little more but overall pretty minor. None on the front that I’ve noticed at all. I am putting motobilt inner fenders in front and rear later today or Thursday which may help a little with the rear rub. We will see. Like I say, it’s real minor.
ChattVol
Tennessee
JLU 4 door
Nice...I installed motobilt rear liners and artec knockoff front liners a few weeks ago and like them. I used a nutsert on the driver side due to access. I'm also running 2" bumpstops and have 17x8.5 wheels 4.75 backspacing(0 offset) and 37s rub the front inner liners a bit when flexing up and turning a decent amount. I imagine yours would rub a little more with +12 offset wheels...think a backpacing of 4.25 or less would clear 37s in front at full stuff and full lock.
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
It tucks up under the flare so I will let you know. Haven’t had any rubs in the front though so we will see after inner fender install.
Jerrybizzle
Jerry
Idaho
2019 JLUR
Tech
Here’s the liners. Sorry for borrowing your thread OP!
Jeep Wrangler JL Calibration after 37s? What else? 018726B6-85DA-4807-8526-D72FC503A829
Jeep Wrangler JL Calibration after 37s? What else? 18E31B10-664F-4764-86DA-6C635963BF05
Jeep Wrangler JL Calibration after 37s? What else? A3AAEC6F-87AD-4ED0-AD21-7C5035D6FEBC
Jeep Wrangler JL Calibration after 37s? What else? 151EF2D4-B090-45EA-A45E-FA5D25020E33
