^ This guy here knows what he's talking about.37" Nitto Trail Grapplers at 34 psi cold, per chalk test
I run 12. Works great.15psi
Great post, I agree with everything but snow. Tall skinny tires work best in most deep snow conditions. You don't want a ski, you want to bite the ground. Sand is probably the most important place to air down. To see what pressure vs. drop/foot-print, use my BigTire39s site.6 - Snow/Rain/Sand/Ice/Mud/Rock handling - important for many of us
These last 3 factors usually call for lower pressures.
Agree. I was thinking about the hard-packed icy-snow typical of what we get in the roads in New england. Fresh fluffy snow is different.Great post, I agree with everything but snow. Tall skinny tires work best in most deep snow conditions. You don't want a ski, you want to bite the ground. Sand is probably the most important place to air down. To see what pressure vs. drop/foot-print, use my BigTire39s site.
Studded tires are amazing on ice and snow pack. I always had a set of 4 studded tires/wheels when I lived on the mainland. Tall and skinny so they worked in deep snow too.Agree. I was thinking about the hard-packed icy-snow typical of what we get in the roads in New england. Fresh fluffy snow is different.
I forgot to say, the side walls are 1” thick and at the hammers they break them in at zero, then adjust based on weight - flex. One tires 20 psi is another tires 30psi.I went through a lot experiments and consulted maxxis engineers, unloaded I run no more the 20 psi, no heat no issues. 37x13.5x17, both treps and creepy crawlers. It really depends on tire of interest.
If that which I think it is is a E rated Tire that's way too much that's a 10 ply you should be running about 26. I run 28 in my 37 12.:50. Do a chalk test and you'll see but in a 10 ply Tire the Jeep's not heavy enough for that you need to run about 26. That's a very heavy Tire in a 10 ply. Lower and you'll see how much softer the ride isJust installed 37x13.50 r 20 Nitto Mud Grapplers and wonder what others are running for pressure during daily driving. Shop mounted them with 38-40.
