Bypass Aux battery
Raddada
Chad
Pennsylvania
2021 Jeep Wrangler 2-door
I have a 2021 Wrangler JL 2 door and I want to bypass the aux battery. I have read through multiple threads and I am not sure what wire going to my main battery needs to be disconnected. Can anyone point me in the correct direction please. Everyone says to remove the wire to the ground terminal but all I see is the main wire and a small wire underneath the main one. Thanks in advance
Jeep Wrangler JL Bypass Aux battery PXL_20260522_120435725
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
That setup looks like you may have etorque. Do you have an alternator? Is this a 3.6 or 2.0?
Raddada
Chad
Pennsylvania
It is a 3.6 and not etorque
Raddada
Chad
Pennsylvania
No bought it from the factory.
Terrymo
Terry
2023 JLURXR 3.6 ET
Not saying you’re wrong but many, many people have been mistaken. What leads you to say not an etorque. Etorques come with an empty battery box in the inner fender which can cause confusion.
I recommend looking under the Jeep for a small suitcase size battery opposite the gas tank, outlined in red in the pic. People say I’m needlessly hurting peoples backs with my suggestion. You can also check your window sticker or build sheet, , or post a pic of your alternator (or generator if etorque) and the number of coolant reservoirs under the hood.
Etorque battery outlined in red.
Jeep Wrangler JL Bypass Aux battery IMG_0723
Jeep Wrangler JL Bypass Aux battery IMG_0828
Jeep Wrangler JL Bypass Aux battery IMG_0829
yokramer
Snark Incarnate
I think you may have etorque
Stuckinthesand
CJ
NJ
What year did the 3.6 switch to etorque only? I thought it was 21.
Raddada
Chad
Pennsylvania
Now knowing it is an etorque and I am getting this message, does it have anything to do with the etorque battery or could it just be my main battery.
Jeep Wrangler JL Bypass Aux battery PXL_20260519_100857275
Terrymo
Terry
2023 JLURXR 3.6 ET
Just your main battery, almost with a certainty, being slightly below a voltage threshold at start up, if the message goes away once driven a bit Common and not a cause for alarm but could indicate your battery is reaching end of life if it is the original,
