Brighter reverse lights for 2023 392?
JPROCKS
JPROCKS
Graham
BCS Mexico
2024 Jeep Wrangler Rubicon X 3.6L
I overdid it and installed all three of these - in my opinion, they’re listed here in the order of easiest to install to most difficult and also in the order of least additional lighting to most additional light.
For me, Oracle flush lights are the sweet point, but even the hitchmount pod is a huge improvement vs stock!
I don’t regret doing all three though, learned a lot while installing :)
This is great, thanks for the feedback
smokeythecat
2021 Willys Sport 2-door, 2019 Mini Cooper S
Fast-n-Furious
PA
2022 392 XR
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
I have a bit written about the Oracle reflector replacement light on the left side of the Jeep. There are others who have had to take a Dremel, belt sander etc.
The passenger side fit right in no problem, Check out some info here on them, BUT I love them now that I got a replacement drivers side light, that after finally sanding it enough and I didnt break the seal of the lense and base and it went in no problem but it was sticking out a little more then the other so I kinda made the mechanics fist to tap it in and I swear it hit it lightly but I managed to crack the lense. Color me stupid lol Oracle said that they originally designed the lights to be used with plastic bumpers, But why does one fit perfectly and the other is no where near fitting at all
There was mention on the forum about a small sledge hammer and a piece of wood and it fit
And they are not very difficult to get out I believe I used a 1/4 drive 6 inch extension and a swivel and you'll get it
JPROCKS
JPROCKS
Graham
BCS Mexico
Had the Oracle flush mount tail lights installed yesterday and now the blind spot detectors do not work on both sides. They need to call Oracle Tech support on Monday to see what the problem is. Anyone run into this issue?
ORACLE Terry
Peak Sponsor (Level 2)
Terry
New Orleans, LA
Gladiator, Wrangler JL, Bronco, RAM TRX
JPROCKS
JPROCKS
Graham
BCS Mexico
Thanks Terry, I did look at the troubleshooting documentation and the shop I had install got the same information from Oracle Tech Support. I need to take the Jeep back in so they can take photos of the working and send to Tech Support.
ORACLE Terry
Terry
New Orleans, LA
Let us know how it goes!
MattT69
Matthew
Utah
Jeep Wrangler JL Rubicon
How does the blind spot detection work on flush mounted unit? I thought it needed to stick out a little to see past the fenders...
I'm looking to replacing my factory OEM LED rear light, thanks
Mifsuud
Phoenix AZ
21 Wrangler Rubicon 4xe
Sadly this is very common. In fact so common when I called Oracle about it a year ago they simply offered to RMA for refund. Nice offer but I'd prefer they work. Has been a known issue. Up to now I think very few JLs have had the blind spot monitoring option.
REWJeep
Bud
TX
2022 Sahara Altitude Unlimited
If the OP's only use case for brighter illumination while in reverse is one location at home, another solution might be solar-powered, motion-triggered lights mounted along his driveway. I use one of these: https://www.amazon.com/gp/product/B083FKXK3N/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 . It provides sufficient light for the JL's backup camera to see clearly. It also makes it easier to find the right key to unlock the backdoor.
Here's mine mounted on the fence next to the driveway:
Jeep Wrangler JL Brighter reverse lights for 2023 392? IMG_2048
