brake fluid flush question
roaniecowpony
Retired Engineer
Oh and is this the same Jscan device people use to adjust for gears/tires etc?
Yes. You do a traditional bleed first, then connect JSCAN and go to the ABS bleed part of the menu. It will provide the instructions.
mgroeger
Southern UT
2021 JLUR 2.0T
There is nothing preventing you from doing a flush/bleed the system fluid without running the ABS. But it won't flush what's in the ABS valvebody/pump.
Question: If you do a flush without ABS and then go out on some dirt or sand and get the ABS to function multiple times wouldn't the new fluid get through the ABS system? Yes, I know that you now mixed the old ABS fluid into the new fluid but I would imagine it's minimal and also you could do another flush.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
I would say yes as well.
roaniecowpony
Retired Engineer
The abs pulses. I believe there is little to flow unless a bleeder is opened.
