Power Steering Fluid Question
DanW
Indiana
What off the shelf power steering fluid is compatible with the Mopar fluid for the JL?
I'm in Moab and am not sure I can find Mopar fluid.
jadmt
jeff
montana
hit the Napa store they should be able to help you out.
DanW
DanW
Indiana
I found on Red Line´s web site that theirs meets the Mopar spec. It was $14 for a full quart. Found it at O´Reilly.
Thanks to everyone who chimed in!
Initial inspection after the day on the trail shows no leak. I´ll get a better look in the morning.
I´m thinking it was drips from an application of Fluid Film awhile back. Not enough to drip on the ground. Time will tell. That power steering system is going to get a workout each day this week.
Jeep Wrangler JL Power Steering Fluid Question PXL_20251022_182151936.MP~3
Blacksport
Ft Lauderdale
'25 Wrangler Sport S, 3.6/manual trans...'23 Corvette C8...'25 Yamaha XMAX
Check to see if you have the electric power steering. If so, get this (Amazon has it): Mopar Electric Power Steering Fluid, 1 pint.
JEEP4U
Richard
2021 Jeep Wrangler
I only use Pentosin fluids for Brake/Manual 6SP and P/S. Can be purchased at parts store...
DanW
DanW
Indiana
I do and I couldn´t do Amazon because I was in Moab. The Red LIne is compatible. After driving trails and then the long run home, It appears there was no leak. Now that I am home, I have the Mopar fluid. So I get my $16 back when I take back the Redline.
The bad news is that the JL had major electrical issues that turned into the dreaded transmission overheat and limp home mode. So I had to leave it at a Jeep dealership in Limon, Colorado. Hopefully Monday they´ll figure it out. I´ll then have to figure out how to get it home. That´s a whole other story that is just beginning to unfold, unfortunately.
WrangleDangle
Atlanta, GA
2020 JLUR
How does one know if he has the electric power steering?
Thanks in advance
20OBMJLURR
Glen
NJ
2020 JLURR
Thanks in advance
Check your book on the glove compartment as I needed some about 6 months ago and it said I needed the Electric power one. My son has a 23 Sahara and he didn’t
