Body mount bolts
Monastero
Billy
Arizona
2024 Wrangler Sport
Hello, I have a 2024 2dr JL. I’m currently installing step sides that bolt to my body mounts. The factory bolts are high strength galvanized (10.9) metric bolts that are comparable to a grade 8 bolt. The new Rock Hard side step bolts are just zinc coated grade 5. I’d like to use new bolts as used ones get weaker (with all the torque I put on them). Why did Rock Hard send me grade 5? Thought these guys were on top of it. It’s really no problem for me to get some grade 8 from the hardware store but if there’s a reason grade 5 would be better than a grade 8 I’d like to know.
I do have experience working with bolts but not in the auto industry. I know about sheering etc. However, these factory bolts are closer to a grade 8. Seems like Rock Hard skimped out and cut some corners here. Otherwise let me know
AcesandEights
Aces
So. Oregon
2024 Toyota 4Runner
Seems grade 5 may be less expensive, but you'd have to verify that. Follow the money.
jac04
CT
2021 Mojave / 2014 JKRX
If the factory bolts are metric, then how do they expect you to use Grade 5 SAE bolts (since there is no such thing as a metric Grade 5 bolt).
Monastero
Billy
Arizona
2024 Wrangler Sport
My bad, They are actually 8.8 the equivalent of sae grade 5
Philly_
Dallas / Detroit / NYC
2022 JL Rubicon
I know some people have swapped out grade 5 hardware that comes with aftermarket bumpers and other items with grade 8, but back when I was researching for my JK, some members of those forums chimed in saying that grade 5 was actually better for the abuse because it would flex more, rather than breaking in high impact situations.
Whether this is desirable for rock rails or even accurate, I couldn't tell you, but thought I would relay their opinions.
Monastero
Billy
Arizona
2024 Wrangler Sport
Appreciate it. Makes sense. Based on these factory bolts (thread locker and torque)and taking them out carefully I’ll go with grade 8.
If one of these bolts was grade 5 or 8.8 and was bent from hard impact I can almost guarantee it will break anyway if I had to take it out. So I’ll take my chances with a grade 8.
Again, thanks for the insight.
jac04
CT
By "grade 8" you actually mean metric Class 10.9, correct?
Yawnie'sPapa
Central Iowa
They'd better not flex. The bolted joint strength is in the clamping force and should not move at all.
I can't think of any Jeep bolted connections that I want to flex. Flexing loosens bolts. They'll stretch and lose their elastic properties and fail.
Bet that weren't getting their info from the Machinists Handbook.........
Philly_
2022 JL Rubicon
Great points! I guess those JK forum members were circulating bad info a while back.
Monastero
Billy
Arizona
2024 Wrangler Sport
You are absolutely correct. They better not flex. People come up with ideas and want it to make sense. But common sense says otherwise. If a bolt flexes it becomes weaker and weaker. As I stated I understand sheering however, I wanted a damn good reason to use a 8.8. As I thought, there is none.
To be honest I’m sure a 8.8/grd 5 will be just fine. But why use it when you can have better. It’s not that much more money. And taking these bolts out is another story. I never reuse bolts on structural areas and I’m not about to reuse a bolt on my vehicle that has been torqued to the max. Not to mention it will snap the next time I take it out.
Take care Y’all. This helped confirm.
