BLOCK HEATER
Outside360
Canada
2024 Wrangler Unlimited Rubicon X
Check your build sheet. If it's on there, they owe you one. AFAIK, all Canadian JLs come with them.
Unfortunately, no block heaters on Canadian Jeeps. I just got that rude awakening on my 2024 Rubicon. They want $1k to put one in!! In a country where -30 is a norm, how the hell do we not get block heaters in our Jeep?! Never even thought to check when I bought it as my last 3 Wranglers had them (just like every other vehicle I’ve ever owned).
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Looks like another 2024 budget cut. They came on every Canadian JL from 18-23 AFAIK.
In saying that, I live in Ottawa and have never used it. Granted, we've only had a few -30 days the last few years so there is that. Not the 2 or 3 weeks we used to get.
Outside360
Canada
Yup.
These new engines aren't like the ones we had as kids. They'll start in the cold without the help of a block heater. I had a little crappy rental car that I left at the airport last year when it went to -50 for a week. I thought there was no chance of it starting without being plugged in. Surprisingly, two cranks and it was running.
Having said that, I have always plugged my Jeeps in whenever it went below -15. Even with better multi weight oils now, I have always thought that warm oil was easier on your engine than cold. Is this dated thinking now?
Dyolfknip74
2021 JLU Rubicon
Yup.
Probably still good advice. Synthetics help a lot more these days I think too.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Do Canadian-spec Wranglers come standard with a low washer fluid level warning light? Just curious.
Pre-heated fluids during cold starts should indeed put less demand on the battery and starter. That said, IIRC, the engine block heater does exactly that: it pre-heats the block, which by extension means it's warming the engine coolant, not the oil collected in the sump on the underside of the block. Not for nothing does post-facto installation of block heaters usually require draining and refilling the antifreeze, while leaving the engine oil untouched.
Dyolfknip74
2021 JLU Rubicon
LOL, no. Missing the context though.
Dyolfknip74
2021 JLU Rubicon
Help us board your train of thought, old boy. What context is attached to a straightforward question about a dashboard warning light?
LMAO. I dont get why you're thinking Canuck JLs don't come standard with a low washer light.......
I turn 50 this week, speak slowly, maybe use crayons.
