Bike Rack Options??
Saejin
Gene
Colorado Springs
JLUR - Firecracker Red
Just in case anyone else is looking at the Yakima Single Speed hitch Mount here’s some pics. I tried to use it without an extension, but the pedals hit on the tire. I have flat pedals, so you may get it to work if you run clipless. I ended up using a 7” extension and it fits perfect.
My preferred mouting is inside the Jeep via a 2x6 and fork mount so I can secure the bike when I know I’ll be running errands and such before or after riding. When I know I’m heading directly to the trailhead and back I use the hitch mount as it’s much faster loading and unloading. Also, despite some reviews online this things doesn’t sway or wobble more than any other hitch rack.
Jeep Wrangler JL Bike Rack Options?? B4E9456B-891E-40D8-B361-5CC80A0DEEE6
Jeep Wrangler JL Bike Rack Options?? 247AF93F-C1E6-4121-803C-286A743DBBE4
Jeep Wrangler JL Bike Rack Options?? B00D687F-6913-4E03-9ED1-E599BF849FA2
Jeep Wrangler JL Bike Rack Options?? 564461F3-B137-427C-8E2F-2C1EED6A0918
Jeep Wrangler JL Bike Rack Options?? 2C791F3D-ED06-4075-B30C-FF0F5DC230E5
Wrangled
Suzanne
Minneapolis
2018 Rubicon JL Mojito Green
I'm going to try the combination of a Yakima Backswing and Dr. Tray rack. The Backswing arrived today and the Dr. Tray should arrive early next week. I'm hoping I won't need a hitch extender. Based on other posts in this thread I don't believe I will but I'll report back when I have everything installed to let y'all know.
Kelowna
Tom
Kelowna Bc
2018 Wrangler JL Sahara Unlimited
@Kelowna - that looks great. Any idea if it will fit with the hard top on due to bar width?
Bike fits no different with the hardtop on. I like having my bike always with me to ride whenever I have an hour of spare time. So being able to safely lock it in the cabin area is important.
Cost for parts were $25 (fork mount), $3.60 for the 2x4, and the spray paint I had kicking around the garage.
It takes me less than 2 minutes to put the bike in or out.
Cheers,
Kelowna
aml
Virginia
Blue JLUR
Picked up our new ride yesterday. The 1up rack fits great with the extender they sell. But I think if I put bigger tires on they won’t clear the rack in the down position. Anyway I prefer the black version they sell. The quality is great! Expensive but no plastic and made in the USA!
Jeep Wrangler JL Bike Rack Options?? 3920C763-FBD5-4C5B-AC26-C9A4DC3274B0
Jeep Wrangler JL Bike Rack Options?? D691D7B6-3C9B-43F6-8158-7D06414AF184
  • Like
Reactions: Cov
Dan S
STL MO
'18 JL Sahara
Elevator Mechanic Apprentice
Can you open the tailgate with that extension? I've currently got a 4" drop extension and would prefer a non-drop version as long as I can easily get in the back.
aml
Virginia
Blue JLUR
You can but it was tight. The rear tire squeaked by. That was why I made the comment about the tire size. I think anything larger than the Rubicon’s stock 33” tire isn’t going to work if you want to open the rear tailgate. I probably won’t be upgrading tires anytime soon, so I’m good at least for a little while.
On a side note, the extender that 1up sells is made by Acme products. Not sure if it is cheaper to buy it elsewhere but I really like how solid it tightens up with no rattling or movement. I am planning on leaving the extension on to tow my little trailer.
Dan S
STL MO
'18 JL Sahara
So, I received my 1up over the weekend and used it with the 4" drop receiver and it works great, but pushes the rack further than I'd prefer from the vehicle and sits much lower than needed. So, I tried it today without the drop receiver. The rack folds up about 1 1/2" from the spare and sits nicely when in use. The bummer is the spare hits the rack by about 1/4" when opening the tailgate... I can force the tire over it, but that's obviously not a great option for the long run. I decided I don't want to get a 2" drop receiver because that's just another patch and it will push the rack further out again. So, thinking of other options I decided to get a tire relocation bracket and move the spare up an inch instead. It arrives on Thursday and should take care of everything. And, if i ever get larger tires, im already set to go.
aml
Virginia
Blue JLUR
That’s a good idea. I should probably do the same and get the hinge upgrade too. I wish it wasn’t so dog gone expensive...there are a few other things I want to get first. Let me know how the tire relocator works out.
Wrangled
Suzanne
Minneapolis
Ok I got the Yakima Backswing and Dr. Tray installed today. This is a nearly perfect solution if you want an easy way to gain full access to your rear gate without removing bikes.
PROS
  • high-quality product,
  • SKS "same key system",
  • built-in locks for the hitch, the rack and the bikes,
  • modular system so you can add a third bike if you want,
  • 4-way sliding trays and tons of room between bikes
  • full 90° swing away from your gate,
  • the lever is not obstructed by the spare tire,
  • rack folds up and out of the way,
  • dead simple operation, the release handle is in the ideal place
CONS
  • very expensive
  • the lock cables could be a tad longer - they scuffed my painted rims because they were tight to reach the pin
Overall I'm very happy with this solution. I had to have a swing-away solution so I could access the back of the Jeep without fuss. This was really expensive ( $299 for the Backswing and I found the Dr. Tray for $505 on Amazon ( yes newer model ) ) so that was not the happiest part, but I feel the quality is high and the ability to synch all the keys/locks is a big plus for me.
Ask if you have questions.
[GALLERY=]
Jeep Wrangler JL Bike Rack Options?? %%zlCYSWQ9WEsWu%ogwFlg
Jeep Wrangler JL Bike Rack Options?? WH9m5FypSSy6k2fSaYaVmA
Jeep Wrangler JL Bike Rack Options?? NnTVSGwCRIiWC7pzbXZe8Q
Jeep Wrangler JL Bike Rack Options?? WZq4mFLmQki0COVPcmNi1w
Jeep Wrangler JL Bike Rack Options?? 5AmHIdnLRCqc8nVOOj048
Jeep Wrangler JL Bike Rack Options?? R89ToXDJQACjIKe0nYQlTQ
Jeep Wrangler JL Bike Rack Options?? so0Um2J1Qz+NU7d4E3jrXw
Jeep Wrangler JL Bike Rack Options?? ShqC8BhkRT2TmldnINnc1w
Jeep Wrangler JL Bike Rack Options?? 6n%97gBXR2Obec4KVQiPiw
Jeep Wrangler JL Bike Rack Options?? BoCiR5X4Rg+yIvW60jkkf
Jeep Wrangler JL Bike Rack Options?? JXNDq+%lSbCKi4UNTMhEqw
Jeep Wrangler JL Bike Rack Options?? aukzWV%BTuamd27qLw1thQ
Jeep Wrangler JL Bike Rack Options?? 7V5WbUgLTwWNFuNSA9trT
Jeep Wrangler JL Bike Rack Options?? pih7JZWRRGyoT3TlBwqX5Q
Jeep Wrangler JL Bike Rack Options?? %gt5Fp%zT6aY6AFg0uxA0Q
Jeep Wrangler JL Bike Rack Options?? HqW2BNu7SzqodItGCOJMMQ
Jeep Wrangler JL Bike Rack Options?? qGNN6Q+7QNKdnw2YhAcpVQ
Jeep Wrangler JL Bike Rack Options?? 0mMMNE0iSPy+zmow15fw2Q
Jeep Wrangler JL Bike Rack Options?? N%nmrLUTRnG98XRvocaDd
Jeep Wrangler JL Bike Rack Options?? XO84s4DVQvi5fcm98jlvQ
Jeep Wrangler JL Bike Rack Options?? YT3z2mheSl+aiivCR3kkDQ
Jeep Wrangler JL Bike Rack Options?? dQkKIB7hSDuUu37HfJ9esA
Jeep Wrangler JL Bike Rack Options?? rgGq+S5RSfuoAZTbSHPHEw
Jeep Wrangler JL Bike Rack Options?? HSxzagIVQZaymzHmNUNp2w
Jeep Wrangler JL Bike Rack Options?? jlIBwGWxQwqOItslLR79v
[/GALLERY]
aml
Virginia
Blue JLUR
I do like the way that swings out, but since I needed a 3rd tray it made it even tighter as it gets squeezed between the other 2 trays. I think the other issue was my kid’s 24” wheels wouldn’t fit without some kind of modification.
Glad it is working for you.
So is that an old PK Ripper or a newly made one?
W5MQS
Mitch
Temple, Texas
2018 Granite Wrangler Rubicon JLU; 2020 Mercedes GLB 250; 2013 Red Ford F-150 4x4
Interventional Cardiology
I have 35" tires on mine and a bumper mounted spare tire carrier so my bike rack wouldn't fit with the spare tire. I bought...mail ordered actually...an 18" hitch extension from Cabella's that works perfectly. It was about $60 with free shipping at the time. I think if I had ordered the 12" extension, it may have been too short.
Wrangled
Suzanne
Minneapolis
That is a new style P.K. Ripper made by SE. They've made 26" and 29" versions of their Rippers and Quadangles and in some cases they put fat tires on them. The call that one in the picture a Fat Ripper cuz it comes with 3.5" fat tires. Very cool bikes. Only one speed but at this point in my life, that's about all the faster I go anyway. Super fun to ride too. Usually I have a sleeker white leather seat on there, but swapped it out for the comfy one today.
Jeep Wrangler JL Bike Rack Options?? qJG4HnWASQKKPMjsJYNCKw
  • Like
Reactions: aml
miller210
lisa
midwest
jeep 2018 jl 4 door
I don't have a JL yet but all of them have backup cameras. It's the law (in the US).
the information said for JL without backup camera so wondered if it worked with back up camera
