Belt chirp on cold start
Opus
Midwest US
www.jlwranglerforums.com
At 600 miles I know I am still just breaking things in with the new Jeep, but I noticed both yesterday and today a quick belt chirp when I first started it up in the morning. I didn't notice it later in the day yesterday and I'll see if it happens again today.
Just a normal part of things breaking-in with the new motor, or something to have checked out? What say you???
quick66
Ken
North Georgia
2022 Jeep Wrangler Unlimited Hightide Edition
Assuming the belt is tensioned properly and the noise isn't coming from a bearing, you can use a little white lithium grease on the belt. Has worked for me in the past.
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
What is the ambient temperature at the time? It might be possible that the alternator is experiencing a small spike at startup and loading the serpentine belt up.
Opus
Opus
Midwest US
The Jeep lives in an attached, but unheated garage. Usually upper 40s in the winter. Could that be the cause?
gsbrockman
Greg
Sand Gap, KY
I have heard of it on some 160A and 220A alternators on Chargers and Challengers........but it’s few and far between.
Deleted member 59498
Guest
Yeah I was going to say maybe cold out. Cold makes things creak.
Opus
Opus
Midwest US
Ah. Yeah, not that cold even on the coldest mornings.
Opus
Opus
Midwest US
Did it again this morning. I paid a little closer attention, though, and it seems to chirp a half-second after it starts to fire up. Still just one short chirp and no other issues or symptoms.
Beachcomber72
2022 JLU High Tide
I’d chalk it up to temperature. But very well the alternator as mentioned above. But either way, more than likely not an issue.
jonyothan
Jon
Ontario, Canada
'22 Rubicon 2dr 2.0T, '10 335i, '03 Golf TDI
HD Mechanic
I wouldnt worry about it. My 2.0L is at 6500km its never done it, but i do fleet maintenance for work and ive heard brand new 3.6L's with less than 10,000kms have belt squeal and its actually pretty common on those for some reason.
if you have ever pressure washed your engine bay that can cause it. if it really bugs you you can spray a tiny bit of silicone spray on the inside of the belt and that will get rid of it
GregorioJL
Greg
Germantown, MD
2018 Jeep Wrangler JL
I haven't used silicone (which is probably fine), but I have found that the CRC Technician Grade Dielectric Grease works effectively and definitely lasts longer than some of the other greases. Clear and slippery.
https://www.crcindustries.com/products/technician-grade-dielectric-grease-3-3-wt-oz.html
robbogo21
Robert
2022 JLU Willy's
I think I’m experiencing the same, only in the cool garage (40-60°F) starting after sitting for a bit. No other issues so I’m considering it normal unless I hear otherwise or it gets worse. 2.0L turbo ā€˜22 JLU 7k miles.
