Battery tender question
Ear Responsible
2025 Rubicon x
Planning on leaving my 2025 Rubicon X unattended in Colorado for a few months this winter and need to buy a battery tender. Looking for advice regarding brands and specific connections needed , taking into consideration I have the auxiliary battery. Prefer not to mess with it due to warranty concerns
AndySpill
Andy
Pittsburgh
2018 JL Sahara
Many people are happy with the NOCO 10.
Your placement of its leads on the main battery terminals with the vehicle parked will charge both the main and Aux battery, as these batteries are connected in parallel at all times when the vehicle is at rest.
Reinen
2021 Jeep Wrangler JL Rubicon
NOCO chargers are highly recommended. You don't need a large one to keep your Jeep topped off while parked. The 2 amp will be more than enough.
yokramer
Snark Incarnate
Ear Responsible
Ear Responsible
2025 Rubicon x
Thank you. Wasn’t sure since the jump start and portable tire compressors connections are different
GinaC
Gina
Newport, VT
2026 Willys 2.0T 2DR Hard Top in Mojito built for me!
Because I usually only drive a few miles at a time, when I don't drive for a few days, I use the Noco Genius 10 and plug it into my towing connection.
Roky
Roky
Another satisfied customer of Norco Genius 10
Jeep Wrangler JL Battery tender question IMG_1393
wave26
Presque Isle, ME
2024 Jeep Willys 6MT
I use CTEK (56-958) MUS 4.3 for several years now alternating between the Jeep and the BMW every two weeks. Neither is being driven much in winter. No problem starting even in extreme cold.
Terrymo
Terry
2023 JLURXR 3.6 ET
You’ll get a lot of me too replies recommending the NOCO Genius 10 including me.
Mguy
Far Away
2020 JLUR 6spd MT
. . . . due to warranty concerns
You mention warranty concerns in one context,
My owners manual, page 356, says to disconnect batteries when storing. A disconnected, healthy and fully charged AGM will loose 3% of its charge per month, suffering virtually no damage if it gets a full charge by about 10% loss.
Jeep Wrangler JL Battery tender question IMG_4565
rsmith56
Roland
Western Texas Panhandle
2024 Wrangler Rubicon Unlimited
Plus 1 on on the NOCO brand, I have them on several vehicles. They are pretty smart. I use the NOCO 5 genius. It has settings for lead acid, AGM, and Litium. It is has a battery repair mode that recently used on some older batteries. One was a 2020 model and the other a 2022 model. Both have been good to go. I don‘t disconnect any of my batteries with one on there charging.
Duane
Myrtle Beach, SC
2026 Jeep Wrangler Sahara
Bought a Noco 5 and it has worked out fine. Work from home and have 2 cars so this one doesn't see that much use. I just move it from the Jeep to the Vette as they both have agm batteries.
