Battery isolator for factory dual battery configuration?
Htfan
Orange County, CA
2018 JLU Sport S - 3.6L
Has anyone thought about adding a battery isolator to the existing factory dual battery configuration? Is it possible?
Problem - the factory system does not protect each battery from the other. So, if one battery fails the other follows not far behind. This happens on a regular basis from the many posts on this forum site.
I know there are $500+ aftermarket options that completely replace both batteries and the factory battery tray. However, I was wondering if an isolator could be added to the existing batteries.
Just a thought... Appreciate your feedback.
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
I have tested using a jumper on N1 to N2 and disconnecting the ESS negative, this removes the ESS battery from the system then once every few weeks you could reconnect the ESS negative and pull the fuse on the jumper to put ESS back into service.
Htfan
Htfan
Orange County, CA
Yes, I read the threads on this subject and your test seems like a good manual system to protect both batteries and keep them from damaging each other. I was hoping there was a way to do this with something like an isolator and not require a manual procedure of pulling a jumper fuse and/or ESS negative cable.
WranglerMan
Will
Greenfield Indiana
Maybe something like this https://www.harborfreight.com/battery-disconnect-switch-97853.html on the negative cable or you could replace the nut holding the ESS negative on with a properly sized wing nut and then all that would be needed is flip the switch and pop in the fuse on the jumper and you will isolate the ESS battery and then reverse it to put the ESS battery back into play but as you stated this is not optimal
Htfan
Htfan
Orange County, CA
Good idea. Something like this would be fairly simple to implement.
