Axle swap time
Surfwagon
Carlsbad, CA
2019 JLU Sport S
I’m looking for a roundabout time to do an axle swap? I do have decent mechanical skill, a friend who used to be an helicopter tech will be helping me and also have access to a lift and power tools.
My only issue is the space I’ll be using is only available for 8 hours a day and you can’t store overnight.
Thoughts?
kah.mun.rah
Merenkahre Jr.
Duat
How assembled are the new axles (shafts, knuckles, ball joints, brakes, etc. included)? If so, you can do it in 8 hours.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
They are full assembled, stock 392 axles with brakes included
Easy peasey lemon squeezy. You should have time for a long lunch even
kah.mun.rah
Merenkahre Jr.
Duat
That will be an awesome upgrade and should be pretty quick, especially since you have access to a lift. I am sure you have already planned on it, but if not, you will need a programmer to change the gear ratio and de-activate the FAD.
Surfwagon
Surfwagon
Carlsbad, CA
2019 JLU Sport S
Yep, already have a JLTazer. So should be good to go there.
Malyk
Langley, BC
2019 JL sport s
I did mine in about 9 hours solo, about 45 minutes was just struggling to get the drag link ball joint popped out. You shouldn't have an issue getting it done in a day. I saved some time and just reused my stock brakes until I get the brake lines to run the upgraded ones so that saved bleeding time.
Jeep Wrangler JL Axle swap time PXL_20240308_202827488
