Junkyard Axle swap
Noflyzone
Ohio
2019 Jeep JL
Parts List
Front Axle
Dana 60 kingpin
Yukon 35 spline inner and outer axle shafts
Yukon hardcore hubs
Yukon 5.13s
Detroit Locker
Solid Axle Steering Knuckles
Solid Axle Diff Cover
Lube locker Gasket
TMR Hi steer Arm
Barnes 4wd 7/8 Heim Joints
Factory brakes
Artec Truss
Rear axle
GM14 bolt
Yukon Grizzly Locker
Yukon 5.13s
Solid Axle Diff cover
Lube Locker Gasket
Factory axle shafts
Factory Brakes
Artec truss
Artec Tone Rings
Custom ABS brackets
4 Rear ABS sensors running to the rear axle
Suspension
7075 aluminum lower links Johnny Joints
DOM uppers Johnny Joints
Metalcloak 2.5 springs
Metalcloak front track bar
Metalcloak Rock sport shocks
Custom rear track bar Johnny Joints
Driveshafts
Tom woods 1410 rear 1350 front
Wheels and tires
ATX Slabs
40 inch Nitto Trail Grapplers
Spent every weekend in the garage for roughly 2.5 months start to finish.
blnewt
New Mexico
Just ask @cosine he knows!
What a project, truly inspiring!
And now the next step is making one of us lowly stockers a killer deal on D44 takeoffs right :) :) :)
Did your daughter save that tire from running over some pedestrians??? :)
Noflyzone
Ohio
2019 Jeep JL
Already sold old wheels tires and axles
Noflyzone
Ohio
2019 Jeep JL
Rear sway bars in the pictures was a metalcloak rear and I found out it was bent. Made a custom straight trackbar with Johnny Joint ends
Noflyzone
Ohio
2019 Jeep JL
She is my garage gopher. She was there for every step of the way including the welding(had to buy her a helmet). She loves working on the Jeep.
RubiRob
Rob
Hampshire, IL
www.instagram.com
Mojave
With how expensive ready to go axles are and with how cheap and DIY loving as I am, I feel like if I ever got to it, this would be something I would do in be future. How do you like it? Happy you did it?
Noflyzone
Ohio
2019 Jeep JL
So after selling rubicon axles, dirty life beadlocks and 38 Patagonia’s I have roughly $4200 in my one ton swap(including new wheels and tires) I am extremely happy with the build. Next is drill and tap the steering box and do my own hydro assist. Right now I’m running unbalanced and no steering stabilizer and it will run 80 down the highway with one finger on the wheel. I am getting about 14-16mpg still with the 3.6 and 6 speed. It is a lot of work but if you take the time and do some research it can be done.
Noflyzone
Ohio
2019 Jeep JL
I was still waiting on ABS sensors from mopar hence the abs lights. Running unbalanced and no steering stabilizer. This was about 750 miles on the new gears and the road was not straight. Jeep drives great.
neil
neil
Dallas, TX
20 JLUR, 21 JLUR and others
f'ing awesome, I have a 2wd 02 yukon I want to do this with and put in a xfer case.
Trill
CA
19 JL
Hey dave can you talk more about your ABS solution/workaround? I assume you're going to run all 4 sensors off the rear just to get the light to turn off, but you will be running without proper ABS/ESC/BLD not that you will necessarily need it.
If you want to get it OEM-like I think Fusion4x4 might be able to help you with hubs and tone rings for the front.
Noflyzone
Ohio
2019 Jeep JL
I have spoke to Fusion and when I work on upgrading my brakes I may swap to dodge/Chevy brake setup. This should allow me to put tone rings on the hubs.
