Axle swap
sourdough
left coast
JL-sold
Learn something new everyday. I have never heard of positive or negitive steer head values and still haven't a clue as to what your are talking about. Camber and caster I understand.
Gregj
Greg
West Texas
It looks at the angle that the steering wheel is turned, the yaw sensor and the wheel speed sensors to determine if it needs to intervene to regain control of your intended direction.
Gregj
colt45
NC
JLU Sport
IMO…. Im about 80% sure it’s just because you need to take it to the good ole dealer and flash the CPU… the gear ratio change will throw everything off. Sounds like you used a tazer and changed the speed, but the abs/stability control still need adjustments via reflash. Not 100% but I am literally finishing the last axle on mine. With the exact same swap. Also the locker wiring may have an impact. Depends on the type of switch you put in.
Jeep Wrangler JL Axle swap 36D35178-35B2-4979-A76B-FEC6FECC184A
Jeep Wrangler JL Axle swap 556F54A0-234A-4406-B071-B9D7C3651396
Jeep Wrangler JL Axle swap D9C5A876-AF26-4B45-A421-7F69D9D755BA
Jeep Wrangler JL Axle swap 9D0FD6EF-B72B-478E-B5B4-CC642FD5D36C
Jeep Wrangler JL Axle swap 59017792-EE72-4F11-B8F2-74A26B6998DE
Jeep Wrangler JL Axle swap 04B1DB51-AE95-4380-A1F7-F3D663A37810
Jeep Wrangler JL Axle swap 8962B6A0-C947-4CFB-B026-E3801D6EBE1A
Jeep Wrangler JL Axle swap 91E127D0-7970-4A95-8125-1D196E0059E1
Jeep Wrangler JL Axle swap FB2D090E-666B-47BA-A301-3AFE62959BE0
Jeep Wrangler JL Axle swap 65FA4B90-36C1-41D4-98FB-0A6C0A32521D
Jeep Wrangler JL Axle swap CB87B34B-AF23-4710-AA8F-BF48618E0DEF
Jeep Wrangler JL Axle swap 33C68165-1353-4D0C-9DE9-F8F515948124
Jeep Wrangler JL Axle swap F60CCD72-C65C-45AD-AE8D-E0BF5147411E
Jeep Wrangler JL Axle swap 54B02400-C486-45E2-B5B4-F2BEDCD3EC5E
Gregj
Greg
West Texas
I did the same axle swap on my Sport and changed the gear ratio in the BCM with JScan and have had zero issues. I did have the steering wheel off center and it threw the traction control error. I centered the wheel and all the errors disappeared. I believe the OP’s issue is a wheel speed sensor error. A good scanner should be able to tell which sensor is not working.
Gregj
word302
Oregon
JLU
There’s no need to get a flash from the dealer if you have a Tazer or similar flash tool.
