Auto Start Bug When Going into Park?
HoosierJL
Fletch
Lafayette, IN
2019 JL Rubicon
Mine rarely shuts off when pulling in the garage. I think it is the slowish stop and light braking that keeps it from stopping. It definitely turns off at stop lights.
RMojitoJL
Skyler
Las Vegas, NV
2019 Jeep Wrangler JL Rubicon *Mojito*, 2019 Jeep Grand Cherokee Altitude, 2019 Honda Civic Hatchback Sport
Loan Officer
if you don't have a lot of pressure on the peddle, it wont shut off... anywhere. if you push the peddle in enough... its doesn't its auto off. Seatbelt off prior is also a easy work around also (aside from the obvious of turning it off when parking)
jellis4148
Missouri
2019 Jeep Wrangler JLU Rubicon
Again, it is an easy "fix". Just take your seatbelt off when you pull into garage. I'm sure the risk of an accident is low in your driveway. This is a simple solution. ESS is a great feature, in my opinion. I would never turn it off, unless I was off roading, and that's the only time I would turn it off. Also, like other people have said, learn your brakes on the Jeep. If you don't depress the pedal to a certain point, it won't shut off. You can come to a complete stop, and not have the engine shut off, if you don't push the pedal hard. Again, a simple fix.
JonW
Jon
Huntington Beach, CA
www.socallx.com
2012 Chrysler 300 SRT8, 2006 Toyota PreRunner, Researching a JL
Here's a suggestion to the engineers/programmers.... Since this "problem" really only happens when parking, use the navigation system favorites to create geofence locations that disable ESS when you are in those locations. Problem solved!
