ARB Twin Compressor Mounting Location?
StuartR
Stuart
Las Vegas
2020 Wrangler JLU Diesel
Anyone mount an ARB Twin on their EcoD yet? Discussing with my mechanic and trying to figure out where to mount mine. He says that inside is not a good idea because when I turn off my locker the air venting from the solenoid would smell awful (gear oil).
Also since using it for my locker as well as airing up running air hose to the back if we mount it in the storage cubby in the cargo area will suck....
The engine bay is super awful for having any space to mount a twin arb.
JLURD
Alaska
2018 Compass Latitude 6MT, 2020 JLUR 3.0
I put mine on the M.O.R.E. mount below the driver side hardtop window and have no issue airing up with dual lines to the front or back tires. I’m not using it for lockers but I can’t imagine there’s no air filtration or window opening solution to the solenoid issue. Otherwise I find that mounting location to be excellent.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Same here. Didn't want to cram it under the hood, due to heat concerns. Aftermarket high tuck fender liners don't leave enough space in the wheelwell location. So, inside seemed to make the most sense for my specific needs. I used a .5 meter stainless Teflon braided line and a remote coupler bracket to reduce the reach and to give the air a chance to cool down.
Jeep Wrangler JL ARB Twin Compressor Mounting Location? 20201117_112108
Jeep Wrangler JL ARB Twin Compressor Mounting Location? 20201117_112048
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
I would mount it in the rear storage cubby or under the brake booster behind the front drivers side fender on the fire wall. There is no way I would mount mine inside of the Jeep. Why, because my wife sits in there while I air up. It is loud and I like my wife comfortable. 110 degrees in Moab, she is in the air conditioning. 8 degrees in Northern Michigan while snow wheeling, she is sitting in there with the heated seat and the heater running. I would not want her to have to listen to the compressor run when there are better locations.
aham23
A
Arizona
2021 JLU Rubicon
I copied Headbarcode. Used the Moore Mount. While it’s loud inside it doesn’t take long. My wife and dog have stayed inside with no issue.
Jeep Wrangler JL ARB Twin Compressor Mounting Location? DF2DECD6-F158-4371-B336-50209180EF1E
Headbarcode
LI, New York
Yeah, in my opinion, it's worth a few minutes of noise to keep an aluminum finned air-cooled unit in a clean and dry running environment. Plus, the winter is my only off season with work, so having the compressor and it's peripherals in a warm cabin will prevent icing in the system.
sylverknuk
Virginia
2023 JLUR EcoDiesel
Mounting it there does not work on the EcoD - The washer fluid reservoir is relocated there for that engine. So, if you were to mount it inside the wheel well on the driver's side, you would need to mod the reservoir tank. A non-starter for me.
