Anyone know what this part is?
Zacreth
Curtis
Hades
'21 Gecko 4xe
So I had my 4xe serviced due to the gas cap not opening and after getting it back I noticed this part was in the back of the jeep sitting on top of the cargo area.
Anyone know what this is?
Jeep Wrangler JL Anyone know what this part is? 20211231_125653
HungryHound
TN & FL
1975 CJ-5, 1983 CJ-5, 1998 TJ, 2021 JLURe
Is it rubber? Size? Could be a drain plug or bumper for fuel door.
HungryHound
TN & FL
It is rubber. I took a picture with the key fob to show size.
Well, half the parts on the Jeep are smaller than the key fob. ? That does help. Looks like a plug of sorts due to the lip around the top. Did you look inside the filler pocket to see if there's a hole that needs a plug? It could be a plug under the storage well or under the jack too.
bossboy302
NorCal
2021 Sahara 4xe
Is there a hole through the center? Maybe a drain...?
Zacreth
Zacreth
Curtis
Hades
'21 Gecko 4xe
How does a gas cap not open? Did they have to remove filler neck?
The solenoid failed so it couldn't be opened. I had to use the emergency cord to open the gas cap.
Zacreth
Zacreth
Curtis
Hades
'21 Gecko 4xe
There's a super tiny hole in the center of the cap looking thing. I'll have to check tomorrow to see if theres a drain plug in the cargo area.
DesertsJL
JLUR
Isn’t there a plug in the back door that looks like that?
Jeeperz Kreeperz
New Hampshire
2021 JLUR 4xe
@Zacreth There was a grommet in the tailgate that looked very similar to that. I used it to pass my antenna cable through. Doubtful it’s that - because your tech wouldn’t have had the tailgate trim off for a gas cap issue. But it leads me to believe itā€˜s a grommet - maybe from somewhere under one of the trim panels on the driver’s side of the cargo area?
Zacreth
Zacreth
Curtis
Hades
'21 Gecko 4xe
@Zacreth the attached pics show a few of those rubber plugs/grommets in the rear cargo area:
It could be one of these, or something similar.
Awesome information and thank you btw! Sheesh this is the reason of finding a good dealership to take our vehicles to but guess it can't be helped really. That's why sometimes it's best to do your own work.
