Another 35 spare tire question
TylerV76
Tyler
Michigan
2021 JLU
I’ve read so much on this that Ive confused myself so I need some help.
I’m having new wheels and tires put on this week. The tire is 35x12.5x17 and the wheels are -12 offset, 4.5” backspace. Weight of the full package appears to be 100lbs per tire
Right now I only have the RC relocation bracket.
If I extend the bump stops with the pvc method, is this safe to run temporarily on the RC bracket? I will be doing some intermediate off roading in a few weeks. Everything except the teraflex alpha hd bracket is sold out everywhere Ive looked. I really dont want to spend $1300 on this.
With this setup, what would you recommend to use permanently?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
You'll be fine. I've been running 100# for a while with no effects. I am about to install a CavFab Elite carrier though.
rhocking
IL
2020 Wrangler 2.0T JLU Sport S
Is the new package for a JLU or Rubicon?
Post pics after install. I am especially interested in seeing how much poke a -12 offset wheel will have. The tool @ https://tiresize.com/wheel-offset-calculator/ seems to show that a 35 x 12.5 R17 will be 3.65" further out than stock on a JLU.
Terpsmandan
Penn Yan
Storm Cloud
Huntington Beach, CA
2023 JLUR 4xe
You'll likely be fine. But I would point out that the Teraflex Alpha HD bracket is not $1300. It's about $365. You are looking at the Bracket along with the tailgate reinforcement. The bracket is all you would need, as it is rated for 100 lbs.
Teraflex Jeep JL Heavy-Duty Tire Carrier|Northridge4x4
There is an entire thread with people talking about running larger tires without reinforcement and having no damage over time. Might be a good read.
(1) Damaged stock JL tailgate from bigger spare tire? | Jeep Wrangler Forums (JL / JLU) - Rubicon, Sahara, Sport, 4xe, 392 - JLwranglerforums.com
TylerV76
TylerV76
Tyler
Michigan
2021 JLU
If the BS of the wheel doesn't let the tire touch the snubber, this is something that I have used on hers:
https://www.amazon.com/gp/product/B004Y75VWW/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&th=1
Thats what I was leaning towards as a temporary fix.
Ok, glad to hear.
This is for a Sport Altitude. I currently have 275/70R18’s so its 3.05 inches more than what I have now.
Im a little worried its more poke than I wanted but since the axles arent as wide as the Rubicon, and Ive seen this setup on there and liked it, I think it’ll look how I want.
TylerV76
TylerV76
Tyler
Michigan
2021 JLU
Thats where I keep getting confused on if I NEED the reinforcement brackets that mount to the hinges. Obviously that’d be ideal.
HydroPaul
Paul
Omaha
2022 jeep wrangler unlimited jl Rubicon
You don't need reinforcement bracket. I've been running 37s with no reinforcement for 3 years. I have the teraflezcu mentioned to get the clearance.
PDXSting
Portland
'22 JLURD '23 JTRD
Just got a set of these:
GOODYEAR WRANGLER ULTRATERRAIN AT 35 X 12.50R 17, and unfortunately the spare does NOT fit :-(
Steel bumper, Rubi
TylerV76
TylerV76
Tyler
Michigan
2021 JLU
New wheels and tires on and it landed exactly where I wanted it.
Jeep Wrangler JL Another 35 spare tire question 3DF512A8-F08C-4F73-AB12-8AAC593E32B4
Jeep Wrangler JL Another 35 spare tire question 14C297F9-865A-41B0-B1DF-6B699283C997
Jeep Wrangler JL Another 35 spare tire question CD914333-4037-4CCD-AC6F-0F2F1308BA89
Got the bump stops extended also with the pvc couplers. $17 at lowes.
Jeep Wrangler JL Another 35 spare tire question F9899F7A-327F-45F2-8AD4-DD71310FAFFC
rhocking
IL
A little bit of poke but not too much. Looks really good.
The reason I worry about too much poke is that apparently in IL you can get a ticket. From what I have read they generally don't ticket for tires poking past fender but best not to tempt fate by going over the top and yours looks perfect.
