Annoying squeaking on 392 rubicon?
ITThisIsDrew
Drew
Depew, NY
2021 Toyota Tacoma, 2021 Supra GR
Brand new (2022) with 700 miles on it. Rubicon 392. Just recently noticed the slightest squeaking/cricket/swooshing sound with the tire from the rear right. Just started. I did get the jeep washed and it has since been quieter/not as frequent now. Should I take to dealer? Or see if it goes away? I am thinking maybe a piece of dirt/sand etc stuck between pad and rotor?
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
This is likely nothing. It'll go away on its own eventually or you can take it apart and pressure wash it out. You'll be alright.
ITThisIsDrew
Drew
Depew, NY
Doesn’t seem to be brakes. As when I brake it still makes the sound. It’s like a rubbing. Ever so quiet. And when I’m going super slow. Like less than 10 mph I hear it! Like a whooshing sound as the tire is rotating. I got underneath and looked at back of wheel. The dust shield behind rotor when I push it is very squeaky. Maybe that??
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Yeah, that’s certainly possibly. It’s just time to take it apart and inspect everything. You’ll find it.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Drew, what you describe is remarkably similar to what we experienced with one of our Honda CR-Vs (we've owned 3) not long after buying it. The sound was speed-sensitive, and it turned out to be a premature bearing failure. Coincidentally, also right rear.
The bearing was replaced under warranty. No problems since then.
Just mentioning this for your consideration.
aldo98229
Aldo
Bellingham, WA
Market Research
That’s what this knob is for.
Jeep Wrangler JL Annoying squeaking on 392 rubicon? 1660259854974
Bzinsky
Usa
2022 rubicon 4xe
I had the worst noise ever happened to mine recently. So bad I immediately drove it to the dealer.
the mechanic drove it 5 feet, heard the noise, put it in reverse for 5ft, gets out and says “all fixed, rock in the brakes”
Just driving in reverse for a second dislodged it. Felt like such an idiot
ITThisIsDrew
Drew
Depew, NY
See that’s funny. Because when I drive it in reverse I don’t hear the sound. Only when in drive at slow speed. Maybe tomorrow I’ll go reverse for a few feet se did that helps at all
Heimkehr
Pennsylvania
2021 JLU 2.0T
My neighbor/riding partner had an almost identical experience with his Triumph Thunderbird. We simply couldn't diagnose the source of a speed-sensitive scratching sound emanating from the driveline.
The dealer tech didn't need five minutes to locate the small, stuck pebble that was making contact with the drive belt pulley.
:blush:
ITThisIsDrew
Drew
Depew, NY
:blush:
It’s like rotational noise. If it’s truly a pebble does it go away on it own?!
