Alternative To Mopar Tailgate Reinforcement
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
Well, I think you did well to NOT choose the Mopar tailgate reinforcement. My '22 392 XR came with one, and I was pretty underwhelmed with it. On a 4 wheeling trip when I still had the stock suspension and 35" tires on it, I had to drop off a rather tall ledge. I knew my Jeep was vertically challenged, so I was being super careful, just barely creeping off the ledge. If I had been going any slower, I would have been stopped. My son was spotting for me and filming with his phone. Right at the closest point I stopped, and he said, "you're good, ease it down". As I eased it off the last little bit I felt a very very faint scuff at the back of the Jeep, just barely enough to feel. Just 100' down the trail I noted that I had a tailgate rattle. After looking things over, the Mopar tailgate reinforcement had bent, and the gate wasn't shutting correctly. There was a tiny scuff on the very rear of the bottom of the spare tire. We watched my son's videos over several times trying to see where it hit, and after about the 4th time through with slow motion you could see just the very slightest scuff as the spare tire barely kissed the ledge. If that was all it took to bend the tailgate reinforcement, I sure wouldn't waste my money on one. It has to be one of the flimsiest Jeep products ever made. I knew I was going to upgrade to bigger tires, so I went with the CavFab rear tire carrier, and it has been rock-solid for two years with 37s, and now even still with 40s.
Bulletbill
Bulletbill
Tom
Central PA
2021 JLUR
I like my TF hinge except for the fact that it’s difficult to lube the hinges. Seems the only way to do this is to remove the hinge from the jeep, remove the c-clips to be able to tap out the pins.
How often do you have to lube them? That seems like it would be a massive pain in the butt.
Terpsmandan
Penn Yan
I went in with a lot of WD40 last summer. Probably going to take it apart next summer.
Bulletbill
Bulletbill
Tom
Central PA
2021 JLUR
Well, other than not spending a fortune on the Mopar that’s not making me feel better about my setup.
Was there any other damage aside from the Mopar reinforcement bending?
3TV
Southwest USA
The tailgate itself was also slightly tweaked. No amount of adjustment on the stock hinges or latches would correct it. But when we installed the CavFab tire carrier, the CavFab part was so beefy that as the bolts were tightened down it pulled the lightweight tailgate straight again. It's better than new now.
shane h.
Shane
DFW
'19 Mojito JLUR (mine), '21 Hellayella JLUR (hers)
Husband, Father, Papa
I just installed the CavFab tire carrier. I'm only on 35s but I wanted to be able to carry additional gear (Jerry Can, 5 pound propane tank, and M.A.S.S shelf) on the spare for some of our outings. Hinges are maintenance free. Gate closes with one finger. Fit was perfect. No shimming required. If you want bomb-proof, the CavFab carrier is it.
Jeep Wrangler JL Alternative To Mopar Tailgate Reinforcement 20250125_175415
azjl#3
North AZ
I personally would not worry about lubing the tf hinge. Unless it squeaks or some other extreme use under water, then maybe just dry lube spray
Terpsmandan
Penn Yan
It doesn't make any noise, just gets harder to open and close when stuff gets into the hinge, especially in a NY winter with all the salt.
Terpsmandan
Penn Yan
Wish TF had thought of those.
JINO
Jino
Socal
2021 jlurd
I went with the teraflex one.
Install was pretty easy, instructions mentioned something about adjustments after, but it was level on the first try.
I seemed to have installed the rear view camera correctly, but now it beeps everytime I reverse.
Jeep Wrangler JL Alternative To Mopar Tailgate Reinforcement 20240901_093640
Jeep Wrangler JL Alternative To Mopar Tailgate Reinforcement 20240928_183557
Bulletbill
Bulletbill
Tom
Central PA
2021 JLUR
Very nice! I wonder if your tire is interfering with the backup sensor
JINO
Jino
Socal
2021 jlurd
That's my guess. They are 38x13.5x17, so on the wide side.
I've tried rotating the camera a bit, but I guess the only way would be to have an extension somehow.
3TV
Southwest USA
Have you tried turning off the proximity sensors to see if that is it? I turned mine off when I bought the Jeep 2 1/2 years ago, and have never turned them back on. I have no beeping with a 40" spare tire mounted on a CavFab carrier. Proximity sensors are in my CavFab rear bumper, but I wouldn't know if they work being as they are turned off.
JINO
Jino
Socal
2021 jlurd
How would I turn them off?
Is it in the stereo setting?
I would 100% them off, I was raised to drive in the 80s and 90s and can use common sense when reversing and don't need to doodads to tell me I'm 3 feet from a curb.
