AEV Borah wheels on JL
AJ CJ5
AJ
Australia
1970 CJ5, 2020 JLUR, Harley Road Glide ST & FXFBS
Explosives.
That XD131 is nice..
nanu
Roger
Nor Cal
2019 Sting Grey Rubicon JLU, 1983 CJ7
Anyone running the JL borah's on a JL and decided to use wheel spacers? Would that cause any issues? I would like a little wider stance then stock, running 37's btw
TIA
DWheelerR
Derek
Jacksonville FL
18 JLUR
Photographer
TIA
Should not cause any issues. Just use quality spacers.
plex
Cincinnati, OH
Want to warn about these bolts coming with Borah protection ring, they are extreme soft and will snap with moderate torque (~20 ft lbs). They are grade 8.8. I have two bolts snapped on me, even though I used generous amount of anti-seize and torque wrench. I drilled one out but the thread is ruined, now I am afraid of drilling the other one.
I replaced all other bolts with grade 12.9, for reference these bolts are M8 x 1.25 x 35mm
Fonzilla85
Fonz
Ventura County, CA
2018 Jeep Wrangler JL Rubicon Unlimited
Lawman
Jeep Wrangler JL AEV Borah wheels on JL 20200802_183924
I was noticing the same thing when I installed mine. Luckily none broke, but I’m dreading taking them off.
plex
Cincinnati, OH
I feel you. I had two broke, and several on the edge of broken. Definitely disappointed since I am a big fan of AEV.
Bryce
Bryce
Acworth, GA
2019 JLUR
Has hanyone run some sort of button head bolts on these? I'm kind of shocked as to how far the supplied bolts stick out to get snagged on stuff
Jeep Wrangler JL AEV Borah wheels on JL 20200725_114612
Fonzilla85
Fonz
Ventura County, CA
Lawman
How hard was it to get that broken bolt out? Seems like a solid hit on a rock would most definitely snap the head off the bolt.
plex
Cincinnati, OH
The good news is they are very soft, so likely a good EZ-out of LHT drill bit should get them out, although you have to go easy on them otherwise the thread could be damaged.
plex
Cincinnati, OH
So I drilled out another one today, PITA. Had to tap the thread and replaced all bolts with grade 10.9 black bolts, now it is much less likely to broke, and I dig the black on onyx look.
You can see some of the AEV bolts I get out are already bent, that is how soft they are.
Bryce
Bryce
Acworth, GA
2019 JLUR
Jeep Wrangler JL AEV Borah wheels on JL 20200807_200129
The black bolts do look good.
