Adding rubicon fender flares with LED
TexaClone
Iowa
2018 Jeep JLU Sport S
Tazer JL update definitely makes me want to get a set of Rubicon fenders for my Sport now:
Update 11.1.4 | 09.03.19
  • Available for Auto Download
DOWNLOAD
  • Added DTC (Engine codes) readout
  • Fixed “Clear DTC” function to have more comprehensive coverage
  • Greatly improved ESS memory function reliability
  • Added Dual Climate control setting for those upgrading from 5″ radio to 7 or 8.4 and swapping in the center stack switch assembly with volume knobs
  • Fixed Winch Mode
  • Fixed Halo Enable function
  • Added ability for Rubicon fenders DRL’s to be used on Sport
Turbo_punkn
Greg
Bath, pa
2018 JL
I just wanna be sure it works before I ditch the flashcal for the tazer.
OC4X4
George
Southern California
Sting Gray JLUR
I haven’t done any programming to LED and so far, for the last 3 hours, they have been working fine. I wonder when they will stop working. Anyone have an idea or experience with this?
I know its been while. I just swapped the fender flare lights on my Rubicon from halogen to LED. The amber turn signals stopped working soon after I would start it and I got the notice in my dash. The white DRL LEDs work OK.
However, after 24hrs the LEDs started working properly, dash alert went away. Keeping my fingers crossed. I'm trying to avoid paying for programing (Dealer attempt , buy Tazer, or buy JScan).
Did yours continue to work?
Tdkrum5
Ted
WA/AZ
20 White JLU Altitude
I have a 20 JLUS with OEM LEDs front and rear. My halos come on in auto. I want to add the Rubicon LED fenders for the DRL. Will i need the tazer or code to get the fender DRL to work with my halos?
df007
2019 JLU Sahara 2.0
Yes you will need a programmer to upgrade the fenders to OEM LEDS. Many have used the Tazer and some (including me) have used Jscan app. Here's a recent post with Jscan details:
https://www.jlwranglerforums.com/fo...mming-led-rubicon-fenders-to-my-willys.51490/
If you already have the two-bulb halogen fenders you don't need to enable the dedicated DRL's and dropouts, just change them to activate LED,
For the most part people don't seem to have good luck with dealers trying to change programming for fender lights. They seem ok with headlights and fogs though....strange.
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
So just to confirm.... in a sport assuming i flash with the tazer for DRLs,
Upgrading to led fenders, will the DRL function when the headlight switch is set to off since there’s no auto mode? Or do i need to wire a 12v power wire to an aux switch like i plan to do so for the led headlights?
I was under the impression my sport had a different wiring harness coming from the bcm and that I’d need to wire 12v power to the leds in the fenders.
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
You may be able to pull your inner fender back and verify the harness going to plug has 5 wires. My 2018 Sport S had proper wire. Just plugged in LED DRLs and programmed with Tazer and everything works great. Also - with my switch turned to off (although I have auto) the DRLs come on.
LanceM
Lance
Marion, TX
www.bigredpawdoodles.com
2018 Jeep JL 2d
System Admin
Just updated my superchip... Before the best I could do was get the orange lights on as daytime running lights... Tried many times/updates over the last year, but this thread sparked me to do try again. Ran the update, went out and BLAM... White DRLs!!!
Howardlv22
Howard
Arizona
2021 JLU EcoDiesel
Has anyone on this thread ran into buying née rubicon fenders that the harness end,(the part that plugs into the inner fender ) is cut off? I’ve spent hours trying to find the part number or what to buy and I can’t . Any help would be greatly appreciated
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Here is a couple threads with part numbers to replace plug.
https://www.jlwranglerforums.com/forum/threads/sahara-rubicon-led-drl-harness-help.20312/
https://www.jlwranglerforums.com/forum/threads/non-led-to-led-fender-light-question.19173/page-2
Howardlv22
Howard
Arizona
2021 JLU EcoDiesel
I got extremely lucky! I went to the dealer I used to sell jeeps at for three years and the head parts guy went in the back and they literally had two full brand new led fender wiring harnesses pulled off from a custom jeep build and he was like here pretend you weren’t here and I bounced ?
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
VERY lucky
