Adding proximity locks retroactively?
Status
Not open for further replies.
RocketScientist
Tom
Massachusetts
2020 Ford F150
Do you think all 3 handles are required? Could you do just the driver's door?
I dunno. I would say probably. If the handle is available, I should have mid-week. But I won't be able to test next weekend - heading to White Mountain Jeep Invasion. Removing the door handle is relatively simple, according to service manual. In the back of my mind, I'm thinking there's going to be some gotcha….
On another note, adding the BSM should be simple, but more expensive - Need to have LED lights, first of all. Which I do. Need radar X2, light harness X 2, radar bracket X 2. And two mirrors. That's a lot more - almost $700 in parts.
Now "why didn't" I just get the vehicle with proximity.... I wanted that. But I did not want to order, and finding a manual transmission Sahara with options I wanted was, hmm, difficult.
Movingday
Murfreesboro, TN
2018 JL Sahara
This would be awesome if it all works. It’s one of those things I didn’t think I would miss as much as I do. It is an even bigger deal for my wife as she just keeps the fob in her wallet. Thanks for working on it. Interested to see how it turns out. Also interested to know if it could just be installed on one door? I really only need the driver door done
RocketScientist
Tom
Massachusetts
2020 Ford F150
I looked at the tailgate.
1) handle removes easily with an appropriate torque bit screwdriver.
2) removing the trim panel.
-wiring goes to swing gate BUT
-a jumper is needed to go from swing gate harness to handle. Current jumper just splits off to lock
Jumper is $11.00.
RocketScientist
Tom
Massachusetts
2020 Ford F150
So I'll leave at that. I think I have all I need for rear gate. I'll see where this gets me.
I poked around on the front doors on tech authority. There seems to be only one wiring harness for doors equipped with power [locks, windows] and no additional requirements for passive entry. i'll have to look in my door... that won't be until the weekend...
I'm doing the tail gate because that is the easiest to access/deal with. But if that one works any other single door should work.
jebjkey
Hawaii
Wrangler JL Unlimited Sport S
Here are the parts (pricing from AllMoparParts):
Rear Gate
Handle, Outside
Part Number: 68309825AB $90.51
Handle, Outside Cap
Part Number: 68309830AC $8.05
Passenger Door/Driver door (same parts)
Handle, Outside, RIGHT or LEFT
Part Number: 68307269AB $86.14
Handle, Outside Cap, RIGHT or LEFT
Part Number: 68307272AD $8.34
$287 plus shipping. AllMoparParts usually provides a discount code if you PM them.
It would be funny if this is the "after purchase" price tag for a $495 factory option at the time of purchase.
Alf1096
Kody
JLUR
Would there not be something special inside the fob itself.
jebjkey
Hawaii
Nope. The same technology is used for the pushbutton start, so the key fob is ready to go.
simpleJL
Kyle
East Bay, CA
'18 JLUR
Wouldn't there need to be a link between the keyfob signal and the individual Jeep? Or is that somehow already in the Jeep's individual ECU already?
Otherwise random JL owners could walk up on open the doors with proximity.
jebjkey
Hawaii
The link is already their for the push button start.
Proximity entry and push button start are the same thing as far as the key fob and car are concerned. The reason proximity entry does not work is because you do not have the sensors in the car doors. If you purchased the Jeep with the proximity entry option, then it came with the sensors in the doors.
jebjkey
Hawaii
You might need to tell the ECU that the proximity sensors are there by going to the dealer so they can load the program. That would be expensive, I am sure. But that would have nothing to do with the key fob.
simpleJL
Kyle
East Bay, CA
'18 JLUR
So you throw the sensored handles in, plug them in, and boom. It should work? In theory.
Edit: you just posted at the same time, saw your post above.
jebjkey
Hawaii
Someone would have to take the risk and try it out before we would know for sure if it works like the 8.4"/7" screen upgrade [plug-in-play] or if you need to program the ECU for the new sensors.
RocketScientist
Tom
Massachusetts
2020 Ford F150
The service manual describes the operation
The RFH module and BCM are the brains. If you have keyless entry and push button start, you have an RF module. Your key fobs are registered to this already. Nothing to do there.
The door handles are merely sensors. They are hardwired to the RF module. They just send a signal to the RF module based on you pushing the button or grabbing the handle. The rf module then sends a wakeup signal to the fob via one of the 5 Lf antennas. If a valid fob is present, it will respond. If the Rf module gets a response, it will send the appropriate lock/unlock signal to the BCM. This same process happens for push button start. So the fob and rf module are already performing this function.
Full disclaimer I’m not an FCA engineer, but I’m not a complete idiot (some parts are missing), this is generally how I read this to work. I may not be 100% correct and there could be a hidden gotcha that I’m not aware of...
As I stated before - my JLUS has the LF antennas in place and connected to RF module. Other trim levels may differ. If you don’t have keyless entry you may be SOL. (Do base JLs have manual locks only?) The handles, cover plates, and a rear gate wiring jumper appear to be all that is required. It seems unlikely to require additional programming. I’ll know definitively next week, hopefully.
BWWJL
Chicago Area
18 JLU Sport S
Can’t wait for the results!
Richamby
Ric
Harvest AL
2018 JLU Sahara born on 5-18; 1999 TJ 2 Dr
part number for the jumper?
Status
