Proximity Locks Issue
RubiHOG
Emil
Louisiana
2020 JL, 2017 Harley Road Glide
My jeep is about three months old and it seems to have developed a problem with the proximity locks. They work on the passenger side and the tailgate (2-door model), but when I put my hand in the drivers door handle nothing happens. If I pull the handle it then will recognize that my hand is in there and it will unlock the door. The problem is, it keeps trying to unlock the door over and over and over again. It clicks every second or so as it tries to re-unlock the door. Then, if I press the button to lock the doors it won’t work. If I go to the tailgate and press the button it works, but then as I walk by the drivers door with the key in range it will just unlock by itself again.
Anyone experience anything like this before? I have already made sure that all the fuses are seated properly.
phranque1673
Eldersburg
2019 JLUR Ocean Blue
Did this happen to start after you had the doors off? The pins in the door connector are easy to bend when putting them back on.
RubiHOG
RubiHOG
Emil
Louisiana
I haven’t taken the doors off (yet).
Dkretden
Denver, CO
2020 JLUR 3.6L
Op: this has not happened to me, yet. My Jeep is 8 months old.
a quick trip to a good dealer might solve this quickly. I’m guessing that it’s the connector for the driver door.
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
Could be a bad sensor in the handle or magnet in the cap. Or as mentioned door connector issue. There also isn't much room for the door handle wiring to go around the glass and maybe it is shorting out. Dealer should have a factory procedure to go through to try different possibilities.
calvinf1
Calvin
Northeast
2020 JLU North Edition
no problems with mine. just push the button with your finger and keep your hands away from the handle to avoid the constant unlocking.
aldo98229
Aldo
Bellingham, WA
2018 Jeep Wrangler Unlimited Sahara, 2018 Fiat 124 Spider Abarth
Market Research
No problems with mine after 14 months.
Sounds like a warranty claim.
RubiHOG
RubiHOG
Emil
Louisiana
Yep, it was a bad sensor in the handle. Dealer replaced it a few months back and all is good again. Thanks for all y’all’s input!
JimmyZ
Jimmy
2021 2-Door JL Snazzberry Rubicon
My passenger side (2 door) isn't working... Same thing as others posted here... Put hand in and nothing... Troubleshot and nothing .... Assuming bad sensor. Off to the dealer again ☺...
