Adding a drain plug to the ZF 8 speed automatic
RamblingJeeper
Tim
Las Cruces, New Mexico
2021 Jeep JL Rubicon
I added a drain plug to my transmission pan.
it was simple to do
This is the drain plug I used
https://a.co/d/05GaN2jh
you can also use a bolt in plug, but I opted for the weld in.
It was much smaller and did not stick in to the pan very much.
Disclaimer: modify at your own risk.
Jeep Wrangler JL Adding a drain plug to the ZF 8 speed automatic IMG_0217
This is the weld in plug
Jeep Wrangler JL Adding a drain plug to the ZF 8 speed automatic IMG_0215
The bolt in plug (I did not use it) and the weld in plug
Jeep Wrangler JL Adding a drain plug to the ZF 8 speed automatic IMG_0218
Jeep Wrangler JL Adding a drain plug to the ZF 8 speed automatic IMG_0220
I put my plug in the yellow circle, but I recommend that you drill yours in the blue circle.
See the picture further down to see why.
Jeep Wrangler JL Adding a drain plug to the ZF 8 speed automatic IMG_0221
Before welding
Jeep Wrangler JL Adding a drain plug to the ZF 8 speed automatic IMG_0222
Inside after welding
Jeep Wrangler JL Adding a drain plug to the ZF 8 speed automatic IMG_0229
If you drill with the blue circle it will end up here.
mine is to the right just under the filter.
it does not interfere with anything, but would look better where the blue tape is.
Jeep Wrangler JL Adding a drain plug to the ZF 8 speed automatic IMG_0242
I had to cut my 8 mm hex down to get the stock transmission fill plug out.
Not sure if that is just a JL 2 door problem.
kah.mun.rah
Merenkahre Jr.
Duat
That's pretty cool and I love the ingenuity, but how often do you plan to change the oil in your transmission?
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
I like it. I have a 4 door so it wasn't an issue getting to the side plug. With that said this would cut down on the mess from dropping the pan with fluid stil in it. Drain then drop to change the filter and good to go.
Willys41
Larry
Pleasanton Ca.
2020 Jeep Willys
On my willys I replace the pan with a aluminum pan with a drain plug. On my wife's Rubicon I took my old pan from my willys and made a drain plug set up on my lathe and silver soldered in place.
It has a flange on the outside and a slip over flange on the inside all soldered together.
I can now drain and fill about every 25k.
