AC stopped working, only blows hot
OldGuyNewJeep
Don
CT
Hey OP did you ever figure out what when wrong? Mine just started to do the same. Only blows hot air, and temperature I can only set low or high, nothing in between
There’s only a few things it could be. High pressure cutoff, low pressure cutoff, relay, or condenser.
Unless under warranty, I’d go to a trusted mechanic for diagnosis and repair. I just had to do this with my wife’s Yukon and it was *much* less expensive than the dealer would have been.
m3lover1
Ricky
Bay Area, CA
2019 Sting Gray JLUR, 2007 Yamaha R6
You know my Jeep is super weird. It went haywire after our camping trip, and we were on our way home. That's when it went coocoo. While getting gas I tried pulling fuses for all AC related items and no joy. However when I was almost home I tried hitting Max A/C and lo and behold that blew cold air, but only if I hit the max option. Still can't change the temperature.
The next day, I was going to try to reset using Tazer and also just disconnect the battery and reconnect to see if that fixes it. But before doing so I started the car just to check one more time. And everything went back to normal lol. A/C working normally, I can change the temperaure, and my offroad pages came back. Super weird.
Thanks for your help though!
OldGuyNewJeep
Don
CT
HVAC on these things sucks. I miss old fashioned analog sliders.
At one point my head unit was bricked, but HVAC still worked. I thought that was weird.
Oh, well. Glad you’re working. My wife’s Yukon cost $900 to fix.
Jimac
Jim
Kingston, OK
2018 JL Rubicon
Mine cost $1400 for new condenser and install . 30,000 miles but out of warranty by 6 months. Hole in someway
OldGuyNewJeep
Don
CT
Yeah, I had done my research. GMC dealer would have been 1,300 - 2,000. Found a great local mechanic via a friend, instead.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
lol, no. The hvac control module, the body module, the pcm, multiple sensors, compressor clutch, 4 actuator motors. The most likely problem is the hvac module, but it’s just a guess.
RedWhite05
Ryan
North Carolina
2021 JLU Rubicon
I have the same issue with mine. Did you happen to notice the ambient temperature fluctuating? With mine the temperature will show extreme cold temperatures. Obviously the AC compressor will not come on with temperature readings that low. After trying a few things with no success my dealer changed the body control module. That fixed it for a brief period. Maybe a month or so. Now I’m having the same issues again. I lived with it for a while but obviously no AC is an issue in the summer. I’m taking it in again this week. I also get random hood ajar warnings as well.
mwilk012
Oklahoma
Service
Sounds like you have a wiring problem.
RedWhite05
Ryan
North Carolina
2021 JLU Rubicon
Re-wiring was the first attempt to fix it. That didn’t work. Next was changing the ambient temperature sensor. That didn’t help either. The third attempt was the body control module. That fixed it for a month or so then things started popping up again.​
The ambient temp sensor, hood adjust sensor, and body control module are all in line on the wiring diagram. I’m beginning to​
Think it may be a software issue and not an electrical component. I’ll find out more info next week​
mwilk012
Oklahoma
Service
What do you mean by rewiring? Did you do the work yourself?
Jst42ln
NJ
2022 High Tide
New to this forum. Thanks for the add. I have a 2022 High Tide edition. The AC has this random quirk, start the jeep and passenger side blows hot, drivers side cold. I've tried all the adjusters, floor ,,defrost. O ly this g that seems to work is shut it off and restart. Any o e having this issue?
JeepCares
Auburn Hills, MI
JL
Hey there! If you end up visiting your dealership for this and need an extra layer of assistance, send us a private message.
Kate
Jeep Cares
CincyJLRubi
Cincinnati, Ohio
2021 Jeep Wrangler Unlimited Rubicon
I'm resurrecting this thread. The A/C on '21 JLUR suddenly stopped working. Less than 9k miles. Worked fine one minute. Ran into a store and started it back up an nothing. Compressor is not kicking on. 10 amp fuse under hood is fine. Swapped relays and no difference. Dealers are all booked for 3+ weeks!!! NOT happy. Nearly brand new and can't even get reasonable service date on a critical item.
Any suggestions?
Jeep Cares??? Any input on the inability to even get a reasonable service appointment?
Schmittyrunner
Yoli
DFW
2019 JLUR Ocean Blue
Kate
Jeep Cares
I have went to the dealer several times with this issue and they replaced the control (not sure name) but I still am having the issue and even worse! This was all under warranty, but now I'm out of warranty and still need it resolved. I just can't leave my vehicle for 5 days to diagnose every single time. Any suggestions? Thank you in advance.
mwilk012
Oklahoma
Service
Get a loaner vehicle. It will make them work faster, and you won’t be out of a ride.
