6 Speed Manual performance difference?
Direwolf
MA
Would anyone with a Sport, 3:45 s MT chime in ? Those P245/75/R17 are about 31.2", would like to know how it pulls in 1st gear, thanks
I did some of the math in another thread, pasting here. Sport tire circumference is approximately 98.86" and Rubicon is about 102.76". So multiplying that all out and converting to mph...
1st gear sport: 1000rpm / 3.45 / 5.13 * 98.86" * 60m/h / 63360"/mi = 5.29mph per 1000rpm
1st gear Rubi: 1000rpm / 4.10 / 5.13 * 102.76" * 60m/h / 63360"/mi = 4.63mph per 1000rpm
6th gear sport: 1000rpm / 3.45 / 0.72 * 98.86" * 60m/h / 63360"/mi = 37.69mph per 1000rpm
6th gear Rubi: 1000rpm / 4.10 / 0.72 * 102.76" * 60m/h / 63360"/mi = 32.96mph per 1000rpm
Basically, the Rubicon is geared about 12.5% higher than the sport and its speed in any gear at the same RPM is roughly 87.5% of the sport's. That's assuming that I did all the math correctly, of course... Feel free to double-check and put it in a spreadsheet or something.
AZCrawl
AZ
2018 Granite Jeep JLUR
Great job. Can you do the math for a Rubicon on 37's for proper gearing that maintains the stock RPM ranges?
That One Guy
Ryan
Utah
2004 Honda Accord coupe, V6 6-speed manual; ordered 2018 JL Sport 6MT with A/C and anti-spin. D status.
My money says it will pull better or at least as well as a JK rubi with 4.10 gearing. That 1st gear is LOW.
What mph does 1st top out at?
after, uh, engine break-in of course ;)
DanW
Indiana
Direwolf
MA
It's all linear... A 37" tire is 13.12% larger than the stock Rubicon 285/70R17 (32.71"), so you'd need to bump up your axle ratio by the same percentage to maintain stock RPM ranges. That's 4.64, which is probably not available, but 4.56 would put you very close.
Notice that a Rubicon on 37's (13.12% from stock Rubicon) is just a little off from the sport (12.53% from Rubicon).
That One Guy
Ryan
Utah
I'll have to check, but it comes quickly, for sure.
Especially with those 4.10's.
In fact, it'd be great if you and a member with the regular diff ratios posted max speeds in the first few gears one day. Nice little comparison.
DanW
Indiana
I've got a grat speedometer app that will greatly aid this. It snapshots top speed, so I should be able to give a pretty accurate report on it, after work, of course.
That One Guy
Ryan
Utah
Bonus points, if no one with a manual sport/sahara manages to do this before me, I will
DanW
Indiana
Remember, I'm running 35s. It will be different for Rubi with stock 33's.
That One Guy
Ryan
Utah
Ah. Curious, did you get your speedometer recalibrated? I've wondered if that's easy.
Back in the day I brought my 4Runner from 29's to 35's, but regeared the diffs approximately back to stock, so I didn't end up having an off speedometer. But I probably wouldn't regear a Sport on 33's. Wondering if the Wrangler will take a tire size upgrade in the future and have a cost-effective way to maintain an accurate speedometer.
DanW
Indiana
I haven't recalibrated yet. I'm about 4mph faster than indicated speed at an actual 55mph. Maybe 3.5.
Billy
Bend, OR
1997 TJ, 2022 JTRD
Isn't it a quick adjustment through the touch screen?
AZCrawl
AZ
4.56 was my guess, thanks.
DanW
Indiana
I've not seen that and it is doubtful. That would be all to easy to commit odometer fraud.
