4xe speedometer calibration
moments.by.ron
Ron
Macedonia, Ohio
2021 JLU Sahara 4xe
Am I the only one who thinks $329 is INSANE to calibrate your speedo?? Does anyone rent these?
https://www.zautomotive.com/product/z_tzr_jlm/#accessories
Back in my day it was a $40 plastic gear on the 97 XJ.
If "all" you're getting it for is speedo recal, then yeah. Just go to the dealership if all you need is a tire size change.
But if you want all the other features or the ability to change speedo at will (tire swaps [winter/summer, on-road/off-road], this pays for itself.
LJ_3M121318
LJ
Los Angeles
2021 4xe Rubicon
"– Can use backup camera and added cargo/front/undercarriage camera or media player at any speed"
Saw this on the website. Does this mean if we hook up a DVD player we can play a DVD while driving? I would never do that, however out of curiosity can this be done?
eLECTRICON
Guest
The Tazer JL Lite is $219. Your not just paying for the device. You get free updates for new features periodically and the customer service is phenomenal. They stand behind their product and make it right. I've had others like superchip and they don't just "do stuff" for customers. they hide behind their policy whatever that is. So ya it is well worth the $220 to me but I'm constantly doing upgrades to the jeep so I use it more than once. Just read the comments from Joe(z automotive) above. He reaches out to the Jeep community.
MaTeZZ
Martin
Sahara 4xe
About to download last FW :)
Firmware Downloads
Update 11.2.7 | 05.11.21
Tazer JL 11.2.7 available for download
  • Added ForceRWD mode for Wrangler 392 and other full time AWD Jeeps
    • can be activated via live menu or remap cruise button
  • Added support for Wrangler 4XE, including changed Full Reboot changes
  • Added Max Regen button memory for 4XE
MaTeZZ
Martin
Sahara 4xe
So 11.2.7 is supporting live settings on 4xe and latching max regen. Does not latch drive mode just yet.
jahysea
Napa
21 4xe Rubicon, 21 392
I installed this update Friday, it saved my tire size successfully. Latching of Regen button works some of the time, not every time. The Tazer initially caused my Check Engine light to come on for some ABS error but likely I didn't cycle the system enough as it went away after a few drives. Can't really tell if speedo is properly calibrated, trusting that is is.
joe@zauto
Commack, NY
2018 wrangler rubicon unlimited
we may need to make this more clear in the user manual, but the 4XE has a very specific set of steps to making it change tire size without all the warning lights:
must be on firmware 11.2.7
marry, set new size.
scroll to full reboot and select it. Need to be on level ground with your FOOT OFF THE BRAKE so the ABS system can do the necessary recalibrations.
Once that’s complete, you’ll have a check engine light and still some warnings.
do a “Clear CEL’s”. When it says “CEL’s cleared” turn the Jeep off and back on.
now do 2 sleep cycles to finish off the learning process.
)Turn jeep off. Open and close driver door. Wait till dash goes dark then wait another minute after that. That’s one sleep)
if you do all that you won’t have any check engine light or code to have to wait out. The non-4XE isn’t as finicky so the procedure is simpler.
jludave
The Isle of Long
IT Manager
Use Waze or another GPS app to test. Set your cruise control to a specific speed and check if the speed in the app matches. Do this at several different speeds.
Sboden
Kansas City
2021 JLUR 4Xe, 2.5" lift, 17" wheels, 37" tires
Thanks. Just ordered my mini yesterday for my tire upgrade tomorrow.
installer88
Justin
acworth, ga
2017 wrangler unlimited, ordered 2021 rubicon 4xe
I installed my tazer with the updated firmware last weekend. It’s super nice having all the features on top of the tire size change working.
jludave
The Isle of Long
IT Manager
Sboden
Kansas City
I got mine yesterday and it worked just fine. I wasn't sure which 37 inch tire to pick so I picked the smallest.
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Place a level across top of tire and measure to ground for an accurate size
lightsout
PNW
Most 37's are not 37" some in the high 35" range depending on inflation that is why measuring with the level is important to get accurate, I did my tazer today my KO2 35's are only 33.75"
