Jocko
Boston
Hydro Blue 4xe Rubicon
Thanks. I'm hoping I don't have to seek out alternatives, though. I LOVE my coyotes.
Sboden
Kansas City
2021 JLUR 4Xe, 2.5" lift, 17" wheels, 37" tires
I'm wondering if my Lange coyote mirrors will work given how much the charging plug protrudes. It's too close to call from the photos and videos I've seen.
If mine arrives this week, I'll be able to let you know.
dalema
Bay Area
JL392, Golf GTI
[Rebooting the thread now that we're getting our trucks delivered.]
I was thinking about an ARB front bumper to mount a winch, but I'm worried about the weight. The GVWR is going to be a problem, I think. I'm looking at a GenRight aluminum stubby bumper now. I'm not a fan of full-width bumpers, but I'd like to find a lightweight winch-capable stubby bumper that still manages to mount the OEM foglights.
My LOD front stubby and rear bumper finally arrived a month ago from the black friday sales. I put a pause on installing it in case I make the move to the hybrid. Hoping it will fit without issue.
Sboden
Kansas City
I can't think of any reason bumpers wouldn't work. I'd worry more about rock rails, under body cladding, upper front dash spot where charging lights are and anything that has to do with needing a certain area behind the rear seats.
greensprit
Boston
Jeep JK, 4xe on order
Anyone try to install ACE rock sliders onto their 4xe rubicon? I have them sitting in my garage waiting for my 4xe, hoping they work!
Hakan
Hakan
Los angeles
Wrangler Rubicon 4xe
Just put a set of LoD destroyer sliders on my Rubicon 4xe.
Found a few problems
Front bolts are too short. Seems frame have an extra inner layer. Got some 1 1/2 long bolts that solved the issue
Then another issue. The front bolts through frame. Driver side where there is a hole but on inside there is some I think battery coolant lines. They are very tight to this bolt. I had to put it through from outside as bolt head did not fit between the aluminum covered lines. But even now the threads will touch the aluminum cover. Not good. Solution is to make the bolt about 1/2 inch shorter. Have not done this yet. Also tight to get bolt in. Think frame have a extra layer steel.
Passenger side inside of frame have some rubber lines that block access to drill hole from inside. Maybe with an angel drill but I don't have one.
Still happy with result but I know I don't have the perfect bolts in place.
Lifting the rails alone and get the nuts in place is possible as I did that. But recommend having a helper to lift.
Jeep Wrangler JL 4xe mods -- what works/doesn't work from regular JL's? IMG_5698.JPG
Jeep Wrangler JL 4xe mods -- what works/doesn't work from regular JL's? IMG_5700.JPG
Jeep Wrangler JL 4xe mods -- what works/doesn't work from regular JL's? IMG_5704.JPG
Demonic
Austin
MA
2021 JLUR 4xe
Thanks for that info. I suspect I may run into similar problems with the ROAM sliders. If it turns out to be the case I'll just use the body mounts instead of the frame mounts.
rkoco321
Rob
Queens, NY
2013 JK
Hakan, you have sting gray with black fenders and black top? Can we see pictures :)
Sboden
Kansas City
Picture of factory Mopar all weather mats for the rear area.
Jeep Wrangler JL 4xe mods -- what works/doesn't work from regular JL's? 20210414_193756
Hakan
Hakan
Los angeles
Actually the sky top but yes black fenders
Before I got my sliders on it looks like this
Jeep Wrangler JL 4xe mods -- what works/doesn't work from regular JL's? a289d1d0-b60d-4487-a157-8d746bd7f685
Jeep Wrangler JL 4xe mods -- what works/doesn't work from regular JL's? 7faceb1d-6bca-4f6f-95ae-c25b5f693aa8
jjbardis74
Jesse
Keene, NH
2018 JL Wrangler Sport S
Does anyone know if aftermarket underbody skids for the 2.0 will work with the 4xe? Or if new ones are going to be coming out?
JandS
Midwest
4xe | Exige S | R wagon | V Wagon | MB S65
You probably want to cap that bolt with some rubber or something soft. It will wear through this lines eventually and that won't be cheap.
Love the look - I may have to get some of those.
AMC_CJ
Jay
Denver
4xe Curious
I would assume we'll need different skids that are specific to this model as there are significant differences in the under carriage. I'm keeping an eye out for whomever released the first 4xe specific aluminum skids.
