TriumphJeepster
- Jason
- Jun 14, 2021
- South Carolina
- 2022 Wrangler Hopefully
Thank you for that write up. Looks like at least the 35's are in the near future for me.I just had to unique opportunity to drive my '22 manual JLR with factory 4.88s with 37s.
A friend had a set of 37" BFG KM3s on Teralfex Nomad wheels waiting to be used, and he let me mount them up and rip around town for a couple hours. So I got to drive the 4.88 manual combo on 33s, 37s, and then back to 33s, back-to-back-to-back.
My observations:
-First is still plenty short (Probably not surprising). The Jeep still happily pulls forward from a stop by just engaging the clutch, no throttle needed. You can still back out in reverse with no throttle as well.
-Crawling on flat ground in first gear 4low, I *still* could not make the Jeep stall by standing on the brake. It will actually shudder now when idling against a mashed brake pedal like this, but still feels like a tractor that refuses to stall in 4low.
-Can still crawl up small undulations in terrain in 4low, in first, second, and third gears with *no* throttle input. Just engage clutch and it happily walks up.
-Driving around town feels MUCH more natural and intuitive on the 37s. With the 33s the Jeep is absolutely manic in first gear and only slightly less so in second. While this is fun and kind of charming in a weird way, I absolutely prefer how it drives around town on the 37s. The 37s calmed it down to the point that it feels like a normal progression through gears now.
-Still pulls very well around town. First will still get you off the line like you're spring-loaded, second still pulls with a surprising amount of authority, and third will easily get you going up to freeway velocities on an on-ramp. Third and Fourth are still great 'around town' gears for quick accelerating and then cruising at ~40 mph at low RPM.
-With respect to the above note- THIS surprised me the most. I assumed the 3.6 Pentastar would feel like a dog around town on wheels+tires this big and heavy. I assure you on 4.88s it is not. It still revs freely up to the RPMs that it likes to make power, and never felt burdened/overworked. I still had to consciously make sure I wasn't speeding on 45 mph roads, because running through the gears is still so effortless.
Conclusion:
-I am *extremely* sensitive about changes in manual driveability when going to big tires. I initially assumed there was no way I was going to 37s, even with these 4.88 gears. If 37s affected driveability, made low speed crawling difficult, or mandated using the clutch in a mechanically unsympathetic manner, I wouldn't touch them with a ten foot pole. Seriously, I'd rather die of ball cancer than be forced to abuse a clutch because of big/heavy tires.
-After driving these 37s around town for a couple hours, I have NO reservations about setting up my JLR like this. If there's anyone that would admit 'this sucks badly on 37s', it would be me. I wanted to hate it. I loved it. I'm 100% getting 37s now.
-These observations are with a pretty heavy wheel and tire combo. These Teraflex Nomads are ~75% heavier than OEM Rubicon wheels, and 37" KM3s are something like 15 pounds per corner heavier than a 37" K02. It's very possible you may be using a lighter 37" wheel/tire combo than what I drove here.
-These observations are all close to sea level (roughly 1000'). If you're at elevations where the Pentastar is known to be asthmatic, and you need to pass semi trucks uphill in the mountains, I can't speak to that. If you have a 4-door with several hundred pounds of 'overland' gear on it, or a trailer, I can't speak to that.
-What I can tell you is that 4.88s turning 37s on a light, minimalist 2-door at low elevation is awesome.
I really dig the XR wheels, might just do some spacers and 35's in the short term. Drive that until out of warranty and get a lift.
Ugh. Choices. Thank you for making it harder =]
