37 KO2 C rated size ?
sciotola88
Stan
Boerne
2022 Willys Ecodiesel and 2020 JTR
Underwriter
I have this tire on my eco diesel. I have the tazer set at 35.6 and the speedo is spot on.
five9dak
PA
Bikini '20 JL Freedom, '99 Dakota R/T, '11 Boxster
I don't have this tire, but I just adjusted until I was happy with the gps match while using cruise control on the highway.
LCW
Twin Cities MN
'19 4R TRD (gone '22 JLUR) (gone '23 Bronco BL 2d)
I had to adjust the tire size in the PCM going from 35's to KO2 37's. Even though they is not the tallest 37's, they are still taller than 35's.
I know of no tire that is exactly the advertised "inch" size it is always some number below that.
Sure - I get that. I had to adjust (I used JScan) for the 35's i'm running now. But curious if you have decent clearance with 35s (315/70R17 in my case), can these BFG 37s - which run a bit smaller than other "37s" - be used without further lifting or modding.
Here's my JLUR with 35s now...
Jeep Wrangler JL 37 KO2 C rated size ? 3E1A3478-DA70-4268-9652-C83D79BD52A4
CarbonSteel
Ah...I missed that. So the 37" BFGs are 35.375" installed and the 35's (Kanati Trail Hog AT-4) that I had were about 34.5" installed. My guess is the BFG 35's you have are shorter than 34.5"?
I would think for "normal" driving, you could probably get away with the 37's though with some articulation they would likely rub. I had a MC 2.5" lift on mine when I initially installed the 37's (now 3.5") so I did not have any rubbing.
LCW
Twin Cities MN
They are supposed to be 34.4" so they run closer to size than the 37's do. I had to set my JScan to 34.75" to get accurate GPS speed.
But good to know that probably would need a bit of extra lift.
Not to mention probably good idea of beefing up track bars, tie rod and drag link. I don't think I'd be comfortable going any bigger than 35's with stock components.
CarbonSteel
What do they actually measure? Their advertised diameter is 34.4" and I would be surprised if they are anywhere near that unloaded, much less loaded. The 37's are advertised at 36.5" and measure 35.75" unloaded for a difference of 3/4". On my Jeep, they are 35.375" loaded or 1-1/8" difference.
I agree on the suspension components. They are not robust enough for long term use with larger than stock tires.
sweet88gt
sweet88gt
FL
20 JLUR 24 VW Tiguan Rline 20+21 Tacoma TRD
I think I already know the answer but if anyone can shed some light on this. Today I finally got on the interstate. Flat here in Florida and a pretty good head/crosswind say 10-15mph. Maybe a bit more. So at 65 mph it would go into 8th. anything above 65 it stayed in 7th. So I figured that was possible but does any adjustment to the tire size effect final gear in the tuner ? I didnt happen to check it via GPS. Was a short trip of maybe 2 miles.
I did anticipate this just checking.
CarbonSteel
It is because the Jeep is no longer optimally geared and if you have a 3.6L it does not produce enough torque to compensate and when you are in high winds, the transmission has to downshift to compensate for the loss of torque.
The 3.6L engine feels this the most because it produces the least amount of torque. The turbocharger in the 2.0T helps compensate and the remainder of the engines produce enough torque that it is not felt.
3.6L = 285 HP and 260 LB-FT
2.0T = 270 HP and 295 LB-FT
3.0TD = 260 HP and 442 LB-FT
3.0TT = 420HP and 468 LB-FT
392 = 470 HP and 470 LB-FT
sweet88gt
sweet88gt
FL
Sounds about what I had figured.
Down the rabbit hole we go !!
CarbonSteel
I have posted this many times here and for the most part, for most people, these are good combinations:
3.6L/ZF8:
33" = 4.56
35" = 4.88
37" = 5.13
38"+ = 5.38
2.0T/ZF8:
33" = 4.10
35" = 4.56
37" = 4.88
38"+ = 5.13
sweet88gt
sweet88gt
FL
I had figured the was going to be the case.
