yotajeeper
- George
- Jun 3, 2020
- Orange County
- 2020 JLU Sahara 1996 toyota4runner
The axle shaft assembly is after market Dana spicer chromoly. Where can I get the hub ring?Which wheels do you have? Are they hub centric? Most are not. If you run non-hub centric wheels (aka lug centric) and do not use hub rings, this can easily happen. This happened to me a long time ago before i learned why it kept happening.
ive had a tire shop cross thread a lug nut before because theyre in too much of a hurry to start them by hand.Was a total pita to fix on my f150.
the fact that this keeps happening to the same wheel sounds like either the lugs were stretched as mentioned above or your wheels are not hub centric and you dont have rings.
granted, you can run lug centric wheels without rings but you have to be sure that the lugs are centering the wheel when you tighten them. The hub rings eliminate having to do this. They basically make the wheel hub centric.
i wouldnt be surprised if jeep denies the claim because you have aftermarket wheels. It would be highly unusual for the vehicle to have defective wheel studs. Ive never heard of that happening though anything is possile.
