drick
hi,
On my 2021 JLURD i am having some more fun with the entertainment system and audio system. This all started when FCA did an update then we did a Tazer update. This caused the radio to start "stuttering" (i.e. music plays, then cuts out for 1-5s, then comes back on - repeat, repeat, repeat) and the backup cameras to now have a green line down the right hand axis and across the bottom axis.
I took it back into the shop where they removed the Tazer and put a new one in, same issue. We downgraded the Tazer firmware, same issue. We traced all the wiring, nothing found. After about 2 weeks on this, they gave up and sent me back to the dealership to have them try to diagnose.
Dealership tried to update the radio and computer, which didn't work at first. They then talked to FCA and allegedly figured out some way to get it to work, but the problems remain after the update. They then replaced the radio, and updated to all current SW with the new radio - problem remains. Per FCA guidance, they then replaced the backup cams - problem remains. At that point, they too gave up and sent the rig back home with no other ideas of what to do next.
The entertainment system in the rig has been wonky since day 1 (https://www.wranglerforum.com/threads/2021-jlurd-wifi-problems-confirmed-by-att.2442543/) - but this really seems to be over the top and makes using the rig a bit more challenging as this issues also affects GPS, bluetooth phone usage, or pretty much anything that runs through the infotainment system.
Rig is still under 36k bumper to bumper, and i have the FCA platinum extended warranty - which this would be covered under.
I would welcome any opinions or thoughts on this obviously
TIA
D
TIA
D
