2020 JL Transmission Problems
JeffBTV
Connecticut
2020 JL
Hey all,
Received disappointing news from my dealer in Fairfield county in CT.
I was experiencing shifting problems with my 2020 JL automatic, specifically running into 3rd gear. After some time , engine light appeared and I was able to read the code indicating a 3rd gear ratio problem.
Still under warranty, the dealer needed to check with Chrysler corporate for approval. I just heard they won’t approve a new transmission and instructed the dealer to rebuild the current unit, but parts are scarce. The dealer implied this is a known and common issue.
Anyone else experiencing this?
631_Islander
Area Code 631, NY
2020 Unlimited Rubicon with 8 speed and 3.6L Pentastar without eTorque.
Business Development Manager for the US arm of major global Fortune 500 Japanese Electronic Components manufacturer headquartered in Osaka, Japan.
Hey all,
Is it still under full warranty or under an extended warranty? Is Stellantis refusing to approve a new transmission even if you pay for it? Any mods to the Jeep?
JeffBTV
Connecticut
2020 JL
It is still under the original power train extended warranty, I think 5 years. The dealer confirmed this is covered, and originally estimated they would replace the transmission. The dealer submitted paperwork/pictures and after 2 weeks corporate advised they need to repair/not replace the transmission components. No engine mods of any kind. The dealer said he is waiting a response from a nearby dealer who has 5 kits, but is concerned they may need them. This sounds like a a larger issue with the transmission.
JeffBTV
Connecticut
2020 JL
Epilogue
Dealer had to wait 2 weeks from FCA for authorization- would not approve new transmission, only a clutch rebuild kit. Another problem was the kit availability is scarce, so dealer had to call other dealers, but ultimately successful.
For those interested, I earlier detected a P0733 code which indicated a gear 3 shift incorrect ratio.
They installed the new shaft kit and so far so good.
Note this seems to be a common problem as the replacement kit is scarce.
alphawolff
california
2021 JLU
The dealer does not rebuild 8 speeds. I'm really surprised this is what they told you. We don't pull any ZF units apart other than a valve body. This code is relatively common and we always replace the unit for it.
