2019 jlu ess not working/check engine loght
Adam
Oceanside CA
2019 jlu
I have a 2019 jlu with manual transmission. 61000 miles.
last week the ess not working light came on and my highway gas mileage went to crap but vehicle seemed normal. It went off eventually and gas mileage went back to normal. Then the next day the check engine light came on after I got some gas. I disconnected the negative battery terminal and that reset the computer and everything was fine.
Today, the ess not working message came back on while driving on the highway and again, the mpg went to crap. On the same drive the check engine light came back on.
Battery issue/ESS battery issue? Any ideas?
aldo98229
Aldo
Bellingham, WA
Market Research
Start by replacing both batteries with an aftermarket brand.
Good luck.
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
If the ess light turns on while you are driving it's because there is an engine issue and ess is being disabled. This can happen before the engine issue hits the threshold that turns on the check engine light. Read the code when the check engine light turns on.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Gas mileage likely dropped due to the alternator running constantly. If you are on your original batteries, you are doing well at 4 years use out of them. Were there any other drivability issues?
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
Define "gas mileage went to crap" I don't think ESS failure is going to significantly affect MPG unless you are stuck in the JL for hours in traffic with ESS turning the engine off...
One more thing.. do you take advantage of ESS? it not.. then you should remove that stupid ESS battery and run on the main battery only..
Adam
Oceanside CA
2019 jlu
Yeah it's weird for sure. I do the same drive (95% highway) everyday and I routinely am at 20-24 mpg. As soon as the ess not working comes on, I'm struggling to stay at 18 and it's more likely 14-17 Mpg. Same drive, same time, roughly same wind conditions, same speedz, etc.
As soon as the ess not working lightl goes off, mpg goes back to 20-24.
Yogi
Michael
Port Dover, Ontario, Canada
GM, P.Log, CITT, 310T
Nothing, short of an EMP, will screw up a computer faster than low voltage, especially if it's erratic.
Like Aldo says ... replace the batteries.
Adam
Oceanside CA
2019 jlu
I replaced the batteries and both issues persist. The check engine light seems to be from a reported low voltage to O2 sensor (that's what the code reader says). Not sure if that could also affect the electric stop start.
Jebiruph
Jerry
Iowa
Yes it can, ESS can get disabled when an engine issue is detected.
