ESS start/stop not working properly!!!!!!!!!!!!
Laaajeep
Luis
Newark
Jeep sahara 2019
hello everybody....
I have a big concern about my 2019 jeep sahara, the ESS system (auto stop/start) is not working properly. I took my jeep to the dealer 4 times already for same problem, they replaced everything in the system (battery, module and sensors) and works fine for a day or two and then stop working again, the last time it was in the shop, it took 3 weeks to get it back and worked fine for 1 day only.
I'm so frustrated now, I put all my savings for a good down payment, I been making my payments on time for a car that is not working properly. the service department said they did everything they know to fix it.
Please help my. What should I do know, does anybody knows what the issue it could be?. i really hope some one of you guys could help me.
honestly i don't want to start lemon car process
Hope you reply soon.
gsyoung
Tampa
2020 Jeep Wrangler Sahara JLU North Edition
I had an issue with mine as well... ESS just stopped engaging. It took multiple trips. Resolution ended being replacing both the primary & backup battery.
timn1984
Tim
Louisville, KY
Jeep Wrangler Unlimited 2018 JL Sahara,Dodge Journey 2012, Toyota Camry 2015
Yes
What is happening with the ESS not working properly?
Nomad
Ron
Northern VA
2018 JL Sport S
In my manual transmission sport, it was the clutch pedal sensor. If yours is the automatic, I can't help, sorry.
Laaajeep
Luis
Newark
Jeep sahara 2019
Details man, there's a thousand different ways that junk can break.
This system should stop the engine when you stop for example in a red traffic light and when you release the brake engine should be on, but now the engine is on all time.
Laaajeep
Luis
Newark
Jeep sahara 2019
Are you getting any warnings or messages, what does the ESS screen in your center cluster say?
It says "battery charging" all the time
Laaajeep
Luis
Newark
Jeep sahara 2019
Yes mine is automatic
gsyoung
Tampa
The system not engaged when stop the engine keeps on
That's what was happening with mine as I mentioned above. They initially said that my backup battery was bad, but that didn't fix it. They eventually replaced both batteries at the same time and it fixed it.
JimLee
Jim
Too damn close to Death Valley
'19 JLU
It doesn't always stop the engine. There are alot of things that turn it off, for instance if you have your AC set to "Max" it'll never shut off the engine. If your wheels are turned it won't shut off. If you step on the brake too lightly it wont shut off. If your battery is hot, or cold, it wont shut off.
Jeep4Win
Jason
2021 JLR
Is the ESS disengaged?
Laaajeep
Luis
Newark
Jeep sahara 2019
Sounds interesting cause the replaced only the backup battery
Tri-City Jeep
